- Jun 5, 2013
- 144
Alright, so I'm looking for quick advice, and I'll update with more info later. Basically I'm trying to decide what the best way to proceed is. My pool cover collapsed due to a leaking pool, that's another ongoing thread..., but basically I've got perhaps 6000 gallons in a 14k pool right now. It's green, very green. I figured I'd shock the gills off of it while I was working on my SWG install. Basically I dropped a PCV pipe from a return down under the water to avoid a splashing mess, and have the pump filtering 24hrs a day while I've dumped 105 FC worth of Chlorine over the past two days.
This has made 0 difference what so ever. My primary goal was to get the SWG wired and ready, while clearing up the pool some. I've got the SWG done, but the pool is a total mess. I've skimmed the bottom with a net, there's no large debris left. But foul green murk, and there's a white skim on the surface as well.
Do I:
Fill to skimmer level to get the vacuum going? Downside would be more water diluting the bleach, thus requiring more chemicals
Continue on current course and get the TF-100 involved.
I've SLAMed before with great success, I hadn't taken a calculated effort at this yet as I was preoccupied with the SWG, and I really expected the water to clear up some with the bleach I dumped in.
SWG if offline, there's no salt in the pool.
Suggestions?
Do I:
Suggestions?
