Just received my tf100 test kit. Got most of the solids out blind scooping bottom best I could.
Results
PH 8.4
CL 0
TA 90
CH 225
CYA <20
Also, when I turned on the pump noticed a slight leak. Both bolts are tightened. Is there a gasket or something? Any help would be appreciated.
I used the pool math app and it says 5 gal chlorine, 1 gal muratic, 15 cya. I was going to add acid first, then chlorine. Cya once starts to clear. Am I on track? Thanks for the help.
Results
PH 8.4
CL 0
TA 90
CH 225
CYA <20
