Results 1 to 15 of 15
Thread: Pool Steps
    Jun 2017
    Austin, Texas
    85
    Pool Steps
    OK, I have a thread under new build in Austin but wanted to start this on stairs as it's our last major problem solve.
    This pool is 4' 6" throughout. Originally the steps as you can see were set to come off the tanning ledge. The people tanning have asked if we can move those. At 4.5 feet of depth we would need at least five steps correct? Also, these would be very wide and go pretty far into the pool to hit 4.5 feet.
    Does anyone see another good option for stair location and design? To the left of the tanning ledge is what we are thinking but maybe not as wide as that whole bump out since the stairs will go out into the pool almost seven feet if our math is correct.
    Any thouights would be great. Thanks!
    Jul 2016
    DFW
    10
    Re: Pool Steps
    I think to the left of the tanning ledge is the obvious solution. Have them start where the tanning ledge starts so they don't stick out into the pool at all. You lose some deck and bench but retain swimable pool area.
    Jun 2017
    Austin, Texas
    85
    triptyx's Avatar
    Apr 2016
    1,485
    Re: Pool Steps
    I like the second one with the corner steps, but I also like the extended ledge on the first one. I'd blend the corner steps with the ledge extending across to facilitate getting onto/off of the baja step.
    The third option takes too much space away from the ledge IMO.
    8,500gal plaster in-ground with attached spa, two floor drains, one skimmer. Chlorine, City Water.
    Pentair WhisperFlo 1hp Pump, MagnaTek Midcentury EPlus motor, Pentair CleanNClear 200SF Cartridge filter, Purex Triton MiniMax 250 Gas Heater, Pentair SunLite, AutoFill.
    Kreepy Krauly Cruiser, TF-100 with SpeedStir. :D
    Mod Squad kimkats's Avatar
    Jul 2012
    Tallahassee, FL
    35,403
    Re: Pool Steps
    Okay, BAD paintshop but I hope it shows what I am talking about............have the steps follow the wall to the left of the tanning ledge. Keep the ledge a solid block. This will keep the most pool space of all of them. I did the first pick in black. The second pick/idea is done in red. Not as happy with this placement but kind of like how it is by the spa but not ideal.
    Of your steps I like the second set the best. Look very neat!
    Kim
    Jul 2011
    Scottsdale, AZ
    54
    Re: Pool Steps
    I looked at doing the 3rd option you posted when I built our baja step. The guy doing most of the work (rebar, gunite, etc) said he would recommend against that because of a tripping hazard for our kids, but I'm sure it could be potentially for anyone. His opinion was with the kids running around, if they fell coming from the side, they would fall head first into the deck. I have other clumsy family members that this same thing could apply to so we decided against it.
    15,000gal IG Stonescapes Mini Pebble Aqua Blue | Pentair CCP520 Cartridge Filter |
    Pentair Intelliflo VS | Robot TBD |
    12,000gal IG Plaster Pool <> Sta-Rite System 3 S7D75 D.E. FILTER <>
    Hayward Ecostar VS <> A&A In-floor Sytem <> IG Spa <>
    riley00dog's Avatar
    Nov 2017
    Brisbane, Qld, Australia
    2,207
    Re: Pool Steps
    I like option 1.
    3.2 x 6m | inground concrete | ~27,000 litre | 1.2 - 1.8m | salt and pepper mini pebble | SWCG Atral eq35| Viron xt 1.5 HP VS pump | Astral CA280 sand filter | DB3 robot | 2 x LED lights | travertine coping and paving | ceramic waterline tile |
    Uncle Salty's Avatar
    Feb 2017
    South Carolina
    223
    Re: Pool Steps
    I like Kim’s red version she mocked up as they’re closer to the seating area so not as far to go to enter the pool, but of the ones you posted I like #1 the best.
    Salty
    20X40 30,000 gal. Vinyl, AquaPlus Automation w/ T-15 SWG & AquaConnect, EcoStar SP3400VSP pump, ProSeries S310T2 Filter, H Series 400FDN Heater, Sense/Dispense with Stenner Pump, ColorLogic X 3, TigerShark RC990, ​Borates, TF-100 test kit, K-1766 & Speed Stir Finally done! Well Almost
    Tenamarie123's Avatar
    Jul 2017
    Warren, MI
    59
    Re: Pool Steps
    I like Kim's mock-up too as they are closer to where everyone will probably be hanging out so they don't have to walk as far to get in. The only thing I would do is turn the steps so you don't have to walk in front of the hot tub to get to them. Have them sitting parallel to the ledge in front of hot tub, does that make sense?
    riley00dog's Avatar
    Nov 2017
    2,207
    Re: Pool Steps
    Quote Originally Posted by Tenamarie123 View Post
    This would be the perfect solution.
    Jun 2017
    Austin, Texas
    85
    Re: Pool Steps
    Thanks for all the feedback and appreciate the option you drew Kim!
    Mar 2014
    Tampa
    107
    Re: Pool Steps
    I personally would move the hot tub to the far left corner (water feature into pool) with the sun shelf and widen the pool as a result and still open up the space for decking looks crowded by the kitchen
    Jul 2016
    DFW
    10
    Re: Pool Steps
    Here is my suggestion.
    Although I do like Agd38's suggestion of moving the hot tub to the left hand corner. Maybe then slide the stairs and sun shelf from my dwg all the way over to the right and open up some decking around the kitchen. This would also allow you to easily extend the roof or build a pergola over the hot tub in the future if desired. Unless of course you are married to the 50ft of swimming lanes, which is pretty kick-butt in itself. Are you backed-up to a golf course by chance?
    Jun 2017
    Austin, Texas
    85
    Re: Pool Steps
    Quote Originally Posted by d_red1 View Post
    Interesting suggestions...thank you. I will review with pool builder. No, don’t back up to a golf course...nice wooded lot with no views of neighboring houses.
    Aug 2017
    Succasunna, NJ
    396
    Re: Pool Steps
    the pic above me with steps in front of steps is the way to go. Just make sure to put the handrail on the tanning ledge side as a safety buffer for kids coming off there it WILL be a play area esp for little ones. otherwise the wedding style stairs in first set of pics is nice but HARD to do a nice handrail for those right
    14x30 IG 13,000gal "full DIY in progress" hayward automation, aquaplus swg T15, hayward swimclear 525 sqft. cartridge filter, hayward ecostar vsp3400, raypak 266btu NG cupro-nickel heater, dolphin S200 robot
