I seem to have found a engineering software defect in Circupools newer RJ series of salt water generator. I have solar heat which drains the roof panels with a vacuum break when the system isn't calling for heat or pump is off. When the solar thermostat calls for heat, and the pump is on, air and water are mixed for about 15 seconds as the roof panels fill. the Circupool RJ system, which is up and running and stable, samples the water for salt, and in 5 seconds, reads low salt (2100ppm) and shuts down with low salt check cell light.
I have been in contact with circupools tech support, they say they have never heard of this. I am reluctant to remove the vacuum break, have heard of piping collapsing from vacuum and heat. Has any one else heard of this issue? Not sure what I am going to do, the old "classic" models of Circupools SWG didn't have this problem. During initial start up, the Circupool ramps up slowly so the issue doesn't present itself, only during stable running. Circupool says they can't alter the software and currently are discussing this internally.
