ok, off to soak in acid and water again. I'm tempted to put in salt as i need to brush the pool but it's actually only 2 inches from the bottom of the tile so maybe i should just wait and try to figure out how much capacity is in the pool.
tile work done yesterday after noon. It's been more than 24 hrs so good to go to fill pool! I never got to check his work well with the running around and last minute business but i'll worry about that later. he changed out about 6 cracked tiles and there was a lot of gaps from air bubble pockets or something from when the pool was originally put in. that's the last thing i needed to take care of on warranty list I think.So you don't have to stop 3" below? Did you not get the tile work on?
Don't poke the plates and don't over soak them..... When I had a cell that required the acid soak I never left it in the solution more than 10 minutes.
Well, after all that! Will this make you feel better or worse?
14,662 gallons!
If you want to try and figure out how much was in the pool when you started the fill, and how much water you used in the house, then we can work on that. Since one is added and the other is subtracted, it's probably a wash.
I'd plug in 15000 into pool math, test 30 mins after you do chem additions and slowly work your way to 14,500.
Wow, who would’ve thunk a simple pool drain would have turned into all this?? You’re handling it a lot better then I would have, you would have seen a mushroom cloud go off over the east valley!
