I know it seems like a scramble, but as Dirk said, awesome job. You'll have mastery of this stuff in no time and wonder how you ever lived without it.
Someone dangle a salt cell in front of Dirk to distract him from this thread!!
Makes sense that the pool company will want to tell u u have more gallons than u have so it looks like they're giving you more pool than u r.That's ok. Once it's done, take another picture of the meter reading, calculate for units correctly (mine is in pound feet or something funky), and then subtract a "fudge factor". You'll still be lightyears closer to a real number than you're going to be eyeballing it and calculating based on dimensions. For example - a very experienced pool inspector told me mine was about 13k gallons when I bought the house. The calculator on PoolMath said 10k or so based on my average depth estimate with real length/width dimensions, but a meter reading on a fill with children and wife showering and running other water based appliances came in at about 7500. You really don't have to be exact, it's just going to help you to dial in PoolMath a lot better!
I try to look at these experiences as learning lessons.
Let's not overcomplicate this for the OP. She already has enough on her plate. In previous posts and questions over the past 3 years, the listed volume of the OP's pool (14,400 gals) is close enough for our needs.
You can also add chems and test 30 mins after and adjust your gallons in pool math, takes a month or less but works
As I've alluded to, and triplex described, you could almost ignore what you've been using in the house while you fill and still come up with a decent number. If you even guess at an amount used, and factor that in, you'll be that much closer.
However you do it, you can just get as close as you can, don't beat yourself up, then plug that number into Pool Math, then use Cfherrman's method (which you'll also find way way back in one of my posts) and see it you don't start getting better results than the 14,400 you've been using. If you do, great, mission accomplished. If not, fudge the number a bit until you do! And then try again next time you refill!
Go ahead and add some bleach now while it's filling to keep it from sitting too long. I'd leave the pump off until the water level is halfway up the skimmer - you can stir the water with your pool brush in the mean time to keep the chlorine distributed.
cant get a couple pieces of calcium that r at an angle. I think i'll have to soak it again. or maybe a coathanger so i can bed the end to get in the area that is impossible to do with a straight edge since a part of the cell is in the way. left it in acid half an hr so far
