Greg,
You do know that you can connect several data cables to the same com port, right??? It is made to do that...
Too bad you don't have ScreenLogic because it makes setting up the pumps so much easier. Also makes using and programming the Easytouch about 10 x easier...
Anyway, not having the VF pump, this is what I think... When the pump says "Running Schedule", but nothing is happening, it is because the pump is waiting for the schedule to start.. So, if you told the pump to run one turn over at 50 GPM, and it can do that in 2 hours, it will run for 2 hours and then not come back on for 22 hours.. I know that is not exactly what is happening, but I suspect it is related to not having a specific start time or something similar... like time of day is off or some other item is not set up.
Sorry my answer does not point to the exact cause, but maybe it will get you thinking...
