So I decided to buy a new pump but the big question, which one, my plan is to also buy a SWCG as well with this pump and in the future solar heat and/or heat pump or gas heater. My old pump is a single speed, 1 HP (with a 1.1 SF, I think) Hayward SP 2607X10 and the filter is a Hayward S244T, 300 lb sand filter. So I am leaning toward a variable speed pump. I spoke to a local store and they want to change the filter also, as with a larger variable speed pump, he thought my present sand filter is undersized to match the new pump. I have not figured out the head pressure of my system, so I cannot get the flow rate I need to limit the pump so as to not exceed my present filters capacity, but I do not think I need to run a larger variable speed pump at full power, in fact most of the time would run it at much lower speeds than 1 hp to save money, plus if I need more power in the future I would have it. On Hayward web site the owner’s manual for my filter lists the Max flow rate with 1.5” pipes to be 45 GPM, however this is confusing to me because the Manuel covers several different filters that range from 50 lbs of sand to 700 lbs of sand and later gives the 45 GPM with 1.5” pipe for all the filters, unless I am reading it incorrectly. I would think that the larger filters have higher max flow rates. In reading posts on TFP site I have found that mas985 said the S244T filter was 80 GPM Max and 75 GPM normal service (I believe but can’t find the post now to reread) , but would like to know where that is published by Hayward as all I could find was 45 GPM referenced above. I have read about the Pentair Intelliflo and it sounds really nice as flow rates can be chosen or RPM/HP and therefore do not have to worry about head pressure when using flow rates to set the pump. It is also adjustable from 300-3450 RPM, and it is my understanding that larger impellers are more efficient at pumping at lower HP. Also, does this pump have a built in timer and how many times per day can it be set to come on or off and change the RPM? However, the Pentair installed locally by authorized dealer is very expensive compared to buying online and installing yourself, but then the warranty is void or very short and from what I have read they have had some problems with their electrical controls and you have to spend $650 to replace the whole module, which is more than some pumps cost. I also looked at Inyopools PureLine Prime variable speed pool pumps the 1.65 hp model for $599 and the 2.7 hp model for $799. The problem I am having here is the 1.65 hp model does not have a timer and my timer is rusted and needs to be replaced, so it would mean buying a timer also, which is bringing the price closer to the higher hp model which I do not mind but the power rating in the specs say it is variable from ¾ hp to 2.7 hp. I think I may want to run at less than ¾ hp. It also says that speed is variable from 600 – 3450 RPMs. Would 600 RPMs really be ¾ hp, I thought it would be much less than that. I also think that you do not have the option to control the pump by setting flow rate, which appeals to me. Are there any other pumps I should be looking at? Is my logic above flawed?
