- May 23, 2015
- 24,453
- Plaster
- Pentair Intellichlor IC-60
Right-o.
Perhaps Matt will correct me if I'm wrong...
All chemical substances, known and unknown, should be treated with the respect they deserve. This is why old school chemists (and even those in the field today) had and have shorter lifespans. I had a chemistry professor in college that studied and did research on Shrock catalysts (metallorganic carbene compounds) and many of the intermediate compounds are both highly toxic and highly explosive. This professor was missing part of his right ear....
As for "strength" of any chemical, that word has no precise scientific meaning in chemistry terminology. HCl will dissolve many things and it will not affect many things. For example, if I place a bar of pure copper in a cup of 20 Baume MA, all that will happen is the copper will get very shiny. The discolored surface oxides will dissolve, but the copper metal will remain entirely unaffected. If I do the same thing to a pure titanium rod, none of the surface oxide will dissolve and neither will the metal. If I place a chunk of rock in the acid that has a high content of carbonate minerals in it, the acid will bubble and fume like gangbusters and, if it gets vigorous enough, it will over-boil and potentially explode (if hydrogen gas is evolved). If I put a drop of MA in my bare handed palm, I can hold it there for several minutes with no effect. If I get even the smallest droplet of MA on the cornea of my eye, it will burn like crazy and cause severe tissue damage. If I expose a few square inches of my skin to hydrofluoric acid, I will feel nothing. However, the acid will diffusion through my skin and cause massive bone loss as well as severe cardiac arrhythmias that will almost certainly kill me. Less than 0.1mL of dimethyl mercury (less than a tiny droplet) can penetrate most rubber and synthetic polymer PPEs and, once in the human bloodstream will cause irreversible and severe mercury poisoning that will last for several months until the person exposed dies from organ failure or brain damage (it has happened, you can look it up, it's horrible...).
So, as you can see, the "strength" of anything is directly related to the "thing" that is exposed to it...prudence dictates being careful at all times, no matter what you may think is safe or unsafe....
