Thread: SWG Recommendation
    fatboy1271's Avatar
    Aug 2013
    West Hills, CA (Los Angeles County = no water)
    128
    SWG Recommendation
    Back in November I had posted about going on a 17 day vacation and on day one my pool equipment broke: Cracked Backwash Valve, Sand, and SWG No Flow. I have everything fixed except for the SWG. The contractor apparently hired an electrician that didn't read the instructions and he did not put the SWG on a Timer... Therefore, it was on 24 hours a day for 8 months regardless of water flowing through it or not. That is why the grid fins are bent in the picture below. The Pentair Support Tech was actually surprised the housing was still in tact.
    Anyway, this incident isn't under warranty. Luckily I hadn't paid for this portion of the work done yet, so I'm going to by a new SWG on my own and hire an electrician to hook it up properly! For my size pool is the IC-40 a good fit? Is Pentair a recommended brand? Thanks for any input!
    Patrick
    Gallons = 17K / IG / Fiberglass / Filter = Hayward DE-6000 / Hayward EcoStar Variable Speed / Pentair IC40 / 1976, I believe / Shape = "Kidney Bean"
    TF-100 / SpeedStir Magnetic Stirrer / Dolphin Nautilus Pool Cleaner / Wall Whale
    Mod Squad Jimrahbe's Avatar
    Jul 2014
    Bedford, TX
    9,830
    Re: SWG Recommendation
    fb,
    I have the IC40... you don't want to go any smaller... I like my IC40 because works well with my automation system... If I did not have an automation system, I would go with a CircuPool...
    Here is a good comparison chart.. What you are looking for is cost vs. lbs. of chlorine per day.. Compare and Review Saltwater Chlorine Generator Prices and Features
    Keep in my that you already have the Pentair power supply, so all you need is the cell itself.. this assumes you go with a Pentair IC40 or 60...
    fatboy1271's Avatar
    Aug 2013
    128
    Quote Originally Posted by Jimrahbe View Post
    fb,
    Thanks Jim! Great point on already having the power supply. I think I will stay with the Pentair and when the IC40 was running it was doing a great job. I just wanted to double check since the Contractor made the purchase of the IC40.
    Patrick
    Jun 2017
    Sachse, TX
    528
    I believe the self install warranty on the Pentair IC40 is only 90 days.
    Blessings, Paul
    12K, StoneScapes Midnight Blue Mini Pebble w/abalone (July 2017 - executed bi-carb startup Refurb - Sachse, Tx), 3 shear descents on raised Austin stone beam, 2 sprayers, 2 skimmers, 4 returns, 2HP pump, STA-Rite S7M120 cartridge filter, 3/4HP Pump for Polaris 280, Circupool RJ 45+, TF-2006, K-1766, & SpeedStir
    needsajet's Avatar
    Jan 2016
    Sydney, NSW, Australia
    4,537
    wow thanks for the picture. That's a classic!
    12k IG salt; glass beads in plaster; K-2006C, K-1766, K-1106 and CCL test kits; Pentair Eco800 1.2HP VS; Zodiac SWCG 1.3 lb/day (25 g/hr); 25" filter recycled glass; OKU solar panels; 1/2 HP solar pump; Rebel (Warrior) pool cleaner; FlowViz; Other family pools 10K SWCG and 15K on liquid; PoolMath app subscriber; | Read Before Posting to get the best possible advice | ... and this helped me a lot!: TFPC for Beginners
    lightmaster's Avatar
    Jun 2017
    Baxley, GA
    799
    Quote Originally Posted by peirek View Post
    60 days according to discount salt pools. That's why I immediately decided not to get a Pentair cuz I was installing it myself. Circupool has a full warranty on self install.
    Pool Stats: 18' X 48" Vinyl AG, 6,700 gal, Hayward Power-Flo LX 1hp and Easy-Clear C400 cart, Circupool RJ-45 SWG, Dolphin S300, My AG Pool Mods
    Helpful Links: Pool Logger, PoolMath, TF100 test kit, Recommended Chemical Levels, Ext Test Kit Directions, FC/CYA Chart, Chlorine Date Code Calendar, Polyfill Iron Removal, Borates Drop Test
