Thread: Spa Side Remote - Blower randomly powering on
    Mar 2018
    Frisco, TX.
    2
    Have a Jandy Aqualink RS4 coupled with a Jandy 7441 spa side switch. A few months back the spa blower began periodically powering on and off. This would happen when the system was and was not running. First thing I did was troubleshoot the switch by checking continuity from the black wire to the other wires. All checked out but on the side of caution I replaced the switch and found the problem remained. I then proceeded to replace the power control board, completely reprogrammed everything and all functions were normal except for the spa blower which still periodically powered on and off. Next I replaced the relay for the blower, you guessed it, it the problem still remains. Ultimately I removed the white wire from the spa switch block thats connected to the pcb and the problem is gone but as you can guess this kills the ability to use the switch to turn on the blower from the spa. All other functions of the system work normally. The blower can still be activated from the panel inside the house. I'm just at a complete loss as to why this continues to be a problem. Any advice would be greatly appreciated.
    Sep 2017
    Silicon Valley, CA
    464
    Re: Spa Side Remote - Blower randomly powering on
    Sorry to hear that. I had the exact same symptom last year. Fishing a new switch and wires back to the panel fixed it, so I don't have any other suggestions.
    Just confirming that you also replaced the black 6-pin connector. It comes in a separate bag with the new 7441.
    18Kgal play pool+spillover spa, Tahoe Blue Quartzscape refurb June 2017, ~40'x15'
    1.5HP VS JeP, CCP420 cartridge filter, Sta-Rite 400HD, 1.0HP VS JeP for sheer descents
    Caretaker 5-port in-floor system, AP1400 SWCG, Aqualink: RS-8 Combo, iQ20, One-Touch
    K-1005, K-1515 FAS-DPD, K-1766, Taylor 9056 comparator, SpeedStir!
    Mar 2018
    Frisco, TX.
    2
    Correct, when changing the switch I replaced the block with the new one that came with the switch.
    Mod Squad Jimrahbe's Avatar
    Jul 2014
    Bedford, TX
    9,872
    Rob,
    Welcome to TFP... a great place to find the answers to all your weird-working questions...
    This is a pretty common problem with Spa side wired remotes... nothing inside the remote except four normally open momentary switches and a LED lite...
    All it takes is for the switch to build up some corrosion and then moisture can intermittently short them out.. A little change in temperature and they are working again.
    They are often mounted way to closed to the spa water line... Supposed to be about 3" or 4" above...
    Thanks for posting... too bad you did not come here first...
