Results 1 to 15 of 15
Thread: Normal cartridge in DE filter?
    Apr 2017
    Newark
    11
    I bought a house with pool and it has a DE filter with standard cartridges inside it. It seems to work just fine. I need to buy an extra set of cartridges now and have few questions.
    • Should I buy standard cartridges or DE cartridges?
    • Has anyone done this before? Is so, what was your experience.
    • this is a old filter without any backwash mechanism and I couldn’t find DE cartridges for it anywhere. Maybe the manufacturer discontinued support for this model. So, what would be your suggestion if I cannot find DE cartridges, use normal cartridges or getting a new filter instead?
    Thanks for your help in advance!
    ~20-25k gal inground outdoor plaster pool, American Products Titan DE Filter(seems quite old, haven't found anyone else with this yet), solar heater, will add more details soon
    Jan 2012
    'burbs of Augusta, Georgia
    8,857
    Re: Normal cartridge in DE filter?
    Here you go-
    Filter Parts - INYOPools.com
    Maddie
    Skippy's Pool Cooler --> Skippy's New Fountain Our Build --> Our Pool Solved Our Sloping Yard
    Mod Squad kimkats's Avatar
    Jul 2012
    Tallahassee, FL
    35,031
    Me?? I would get a whole new filter to make sure it all works together like it should.
    Kim
    Mar 2010
    124
    Quote Originally Posted by dinesh View Post
    I think what you have there is a Pentair Quad DE filter. The filter elements look like standard cartridges but have more space between the pleats. This is my favorite DE filter, as it is very easy to access and re-assemble. I'm a little surprised that the curved panel filters are still on the market.
    Apr 2017
    Newark
    11
    Thanks for the reply Mayorb. Do you know where can I find the DE cartridges for it?
    I did an extensive search, including calling the company and they all seem to recommend to me the grid assembly (see link http://www.inyopools.com/Products/07501352018484.htm). I even ordered this and it just didn't fit /work for my filter so had to return it. Any help would be much appreciated.
    Quote Originally Posted by YippeeSkippy View Post
    Here you go-
    Maddie
    I can't seem to find what would work for me. The reference model here shows a grid assembly, which doesn't work for my model
    Apr 2017
    Newark
    11
    My current cartridge is 20" tall with the outer diameter of 7" and the inner diameter of 3". And the closest match to that is Pentair De Cartridge, 15 Sq Ft Quad 60 (178654) - INYOPools.com with the outer diameter of 6" (1 inch shorter) rest specifications are almost same. Would this work for my case or do I have to buy the one with 7" outer diameter? Thanks again for bearing with my novice questions.
    Jul 2012
    Tallahassee, FL
    35,031
    Have you called and talked to anyone in the tech part of inyo? If not let me know so I can have a name ready for you to call and ask for.
    Kim
    Apr 2017
    Newark
    11
    Quote Originally Posted by kimkats View Post
    Kim
    It would be nice if you can provide me with the contact at Inyo. Earlier, I tried the tech support for the filter manufacturer but the provided me the wrong information, pointing to those DE grids which didn't work for me. Hoping Inyo would be better to talk and get right information.
    Jul 2012
    Tallahassee, FL
    35,031
    I will work on it. Might be a tomorrow as they are in FL and so closed for the day.
    Kim
    Apr 2017
    Newark
    11
    Thank you!
    Mar 2010
    124
    Does the tank have ANY label or info? Is your backwash valve beige, flat on top, or is it white and dome shaped?
    pentairpool.com/en/products/filters/quad%20de%20cartridge%20style%20filters
    See if that's it.
    Cleaning a Quad DE Filter Overview - YouTube
    Let us know.
    InyoRob's Avatar
    Feb 2017
    Longwood/FL
    101
    Hello Dinesh - Could you post a picture of the filter and the filter label? This way we can determine exactly what you need.
    If you call Inyo again, ask for Andy, Alex, Lennox or Joe. They are the most experienced reps on the phone and will surely be able to assist you.
    Apr 2017
    Newark
    11
    Quote Originally Posted by InyoRob View Post
    Hi Rob, here is the link to the filter picture Shared album - Dinesh Nagar - Google Photos
    It's Amercian Products - Titan Vertical Grid D.E. Filter
    Model No. 188550, Serial No. RPMF3404, Filter area 36
    InyoRob's Avatar
    Feb 2017
    Longwood/FL
    101
    It seems like someone converted your American Titan DE grid filter into a quad cartridge filter. Your cartridge measurements (20"L,7"OD,3"ID) match up with the American Quantum 90 sq ft cartridges. These are different from the quad DE cartridges because the pleats are closer together.
    To answer your original question, the cartridges can hold more debris than the grids and can go longer between cleanings.
    Apr 2017
    Newark
    11
    This is great help Rob. Thanks so much! I guess I should order the replacement cartridges based on the model you suggested.
