I realize this seems like a dumb question, but I can't find an answer anywhere and I'm pretty new at this.
I've tested my water using the test kit for CYA six times over a week, and get the same result - CYA well over 200 (240-260) using the dilution method. Pool guy, who is no longer employed by us, had been using tabs indiscriminately and CYA ended up way too high (it's a salt pool, btw.) I know I have to drain water out, and I'm in the process of doing so with a submersible pump.
Do I need to do anything with the pool equipment as the water level falls? It's all shut off of course, but assuming I need to drain somewhere around 2/3 of the water (and maybe more) I wanted to make sure I'm not supposed to do something with the equipment - that just putting the pump in the pool, pumping water, refilling, then adding chemicals as needed to rebalance is all I need to do.
Thanks in advance...
---Lee
---Lee
