- Jan 4, 2016
- 5,289
- Plaster
Your numbers are an OCLT start of 14.5 to 17.5 ppm FC and then in the morning your numbers are 12.5 to 15.5 ppm FC, which shows a range of 0 to 5 ppm FC loss.
The range of drops suggests testing challenges; a range of six drops is unusual. It's normally easy to tell when there is no pink remaining in the water.
My suggestion of 8-10 was because it might be a bit easier to do the testing. Anything you can do to collect water and test consistently will improve your consistency between FC tests. The same person doing the test will usually have less variation than the test accuracy specification. A few things to keep in mind include: pump running for 15 to 30 minutes prior to sampling; sampling from the same place and depth; testing right away; same fill level in tube; adequate DPD powder; slow (1 per second) drops fully formed before dropping away from the bottle; sample being swirled, slowing down to allow mixing toward the end of the test; white background; that type of thing.
8-10 also works because if you need to resume the SLAM, you really haven't lost much SLAM time.
