Hello,
I ran into some pool problems this winter (pool pump and booster pump needed to be resealed and impeller replaced). I also had very high CYA levels. I partially drained my pool and have made the repairs. I just tested my water. Here are my results:
15,000 gallons
Water temp 60 degrees
Cl 0
Br 0
pH 7.5
CH 250 ppm
TA 80
CYA 50 ppm
My target is:
Cl 7
Br 30 ppm
pH 7.5
CH 250 ppm
TA 80
CYA 50 ppm
If I'm using Pool Math correctly, it suggested adding 96 oz of 6% bleach. However, its not suggesting adding anything to increase Br. Since my pool pump hasn't been running, my water is a little cloudy and has a light greenish tint. I can see the bottom. Should I shock? Thanks for any and all advice.
15,000 gallons
Cl 0
Br 0
pH 7.5
CH 250 ppm
TA 80
CYA 50 ppm
My target is:
Cl 7
Br 30 ppm
pH 7.5
CH 250 ppm
TA 80
CYA 50 ppm
