Hi all!
I’ve read the TFP pool school many times and have found it very informative, thank you for providing that! ����
It’s in my signature as well, I have a 19,000 gallon IG pebble pool and spa that was just built Feb 1, 2018. Unfortunately, my builder abandoned partway through our build and I had to manage the rest of construction to get it done, and now I’m stuck with figuring out start up.
How much acid should I expect to add to a new 19,000 gallon pool? How often are you supposed to add MA? At first, I’ve been testing every day, now every other day to check values and then adding whatever is needed.
My question is will it be an ongoing task to add MA every few days to maintain the pH? Will that eventually stay in range and by when should that happen? It’s been a month since I started up the chemicals with bleach, CYA and MA.
I’ve got the following for readings:
pH:7.5
FCl: 2-4ppm
CH: 210
CYA: 35
My next question is when is it ok to start swimming in the pool??? Is there a check list of what the pool readings should be before it’s ok to open the pool for swimming. I’m in Houston, TX.
Thank you for any help and guidance you can provide ����.
pH:7.5
FCl: 2-4ppm
CH: 210
CYA: 35
