Thread: VS Pump Quetions
    Feb 2018
    Palm Coast
    5
    VS Pump Quetions
    On a variable speed pump, in what situations would I want to use the slower speed and higher speed? Perhaps when solar is circulating? The panels are 100' away from the pump. The outlet options are:
    1. 2 "spa jets". There's no spa, just a couple jets with air control on a lounge type step.
    2. In floor cleaning system
    3. Solar - 100' distance
    4. 2 standard wall returns
    Also, it it normal for the pump to have to prime every time it starts up? Take about 30 seconds for it to start pumping. There's no check valve on the suction side.
    Thank you,
    James
    Mod Squad Jimrahbe's Avatar
    Jul 2014
    Bedford, TX
    9,873
    Re: VS Pump Quetions
    James,
    One of the main advantages of having a VS pump is that you can adjust the speed to fit the situation...
    So for everyone of your options you would adjust the rpm so that it works the way you want. For example on your jets.. you would set the speed so that the Jets looked the way you wanted.
    For your In-floor system, you will need to adjust the rpm so that it functions properly.. etc.
    Play with it, you can't hurt anything.
    Not sure what specific pump you have, but a lot of them allow you to adjust the prime cycle time. Most VS pumps automatically go into a prime cycle at start up.. I don't believe that having a check valve will make any difference.
    You might want to fill out your signature, so that we do not have to guess about what type of pool or equipment you have. It just helps us help you.
    Thanks for posting,
    cfherrman's Avatar
    May 2017
    Hays, Kansas
    1,707
    Solar needs something around 40 gpm to be most effective, give or take depending on the panel and my memory
    Casey
    Intex 24' x 52" closed for winter 2018, 2 Main Drains, 1 Skimmer, 1 Return, PVC
    1/2 HP Intex Pump 633T w/ Taeglus TA-40 175 lb 19.5" Sand Filter, Auqabot Extreme Robot
    TF-50 and Taylor 2006 Test Kits, Quality Well Water, Fleck 5800SXT Water Softener
    PoolGate's Avatar
    Jun 2017
    Damascus, MD
    2,374
    I use 700 rpms for everything accept heating and if I want the water features to run.
    29k Gallon Free Form Gunite Pool, 3 floor returns, 2 wall returns, 1 vacuum pressure port, 2 skimmers, Main drain, Jandy 2.7HP VSP, Jandy JXI400N Gas Heater, Jandy CV340 Cartridge Filter, FusionSoft 1400 SWG, 2 Watercolors LED, iAqualink with PDA, Sheer Waterfall, Rock Waterfall, 9' Deep End w/Diving Board, SunDeck, Polaris 9650iQ, TF-100 - Pool Build - 2017 - Google Photos
