I am relocating my pool equipment about 10 feet away from its current location.
The question or help that I need is with regards to the plumbing. The plumbing is original cast iron and I am looking to convert the cast iron to PVC. not the entire line, just the small section. that will allow a quick rerout 90 around the corner of the house to the new location of the pool equipment.
The cast iron is old and I am looking to cut it and use a fernco coupling since I will not have threads to work with on the cast iron. is there any other option to convert to PVC with no threads on cast iron portion of pipe? my concern is that the pressure on the 2 hp hayward pump may not allow it to hold.
specifically, the cast iron conversion is the return line coming from the Tageus sand filter.
anyone have any ideas or recomendations?
