Results 1 to 7 of 7
Thread: Automatic pool covers and trees/debris New construction
    Feb 2018
    Wyomissing Pa
    23
    Hello!
    We are located in South Eastern PA (outside Philly...way outside)....... We are starting construction as soon as the ground thaws, we are the first dig on the books for our builder. I am getting excited but also am pretty scared, this is a big investment and leap, I want it right.
    Becuase of being in PA where the vegetation is lush and our home location I am worried about tree debris. We have many many oak trees that are easily 50-75 feet tall. They drop pollen, acorns, sticks, squirrels, voles, opossums and everything else. We will be taking 2-3 down before our dig.
    Now that the picture is painted, tell me is this mission impossible to keep the pool clean? I have heard both good and bad. I suggested to my husband that we install an automatic cover that opens and closes electronically. He has shot me down due to price up front and reviews he has read online, stating they frequently fail. With a $12k-15k price tag, I want it to be perfect.
    What says the TFP community? Do you have a retractable cover? DO you like it, are there issues?
    Who in here has a lot of tree coverage and debris? What do you do???
    Thanks!
    PS - I will work on my signature line once I am a little more familiar with the pool world.
    Re: Automatic pool covers and trees/debris New construction
    Automatic covers have a lot of positives, less evaporation, more stability with chemicals, less frequency of cleaning, extending the life of your pool's surface, SECURITY and the time savings associated with all of the above. Do they fail? Yes, but not as a matter of course and not "frequently" unless they're abused or improperly installed.. A robot will help with cleaning issues, but not having to clean as much is a big plus.
    I have a kidney-shaped pool in a n awkward placement in my backyard, so I can't get an automatic cover. If I were building new, I'd absolutely get one.
    Geebot
    Chicago, IL
    30K gal, InGround Plaster Finish, 3.5'-9.5', Maytronics S300 Cleaner
    wjr75's Avatar
    Jun 2013
    IL
    878
    We are surrounded by tree's (Maples, White Pines, Birch and several flowering tree's). The cover keeps all of the debris out of the pool when not in use. I have never hand vaccumned our pool in 8 years and just use our Polaris. The spring time is especially bad with the tree's but you either blow the crud off the closed cover or if it rains you open the cover with water on it until there is about three feet left before fully opening. I then use our skimmer to skim all the leaves and debris out and pump off the excess water before fully opening. Our pool would be a disaster if we didn't have it. We had just recently had to replace the cover at around $2k but the original had lasted about 10 years. We never really have any issues with ours mechanical wise.
    Inground 22k gallon gunite 15x31 main pool, 15x7 wading pool/sunning deck, hot tub/with overflow (9' octagon with limestone top) & slide NSWG, Aqua Blue Pebble Sheen
    Filter dual cartridge Sta-rite 450sq/ft, TF-100 Test Kit
    Heater Raypak 2100 400k btu cupro-nickel exchanger
    Auto pool cover, Polaris 280 auto pool cleaner, Jandy AqualinkRS8 Remote Control System
    Jan 2012
    'burbs of Augusta, Georgia
    8,872
    We have had our auto cover for the almost 7 years of pool ownership. We have had no problems with the cover at all. Ours is by Pool Cover Specialists.
    Home | Pool Cover Specialists
    Maddie
    Skippy's Pool Cooler --> Skippy's New Fountain Our Build --> Our Pool Solved Our Sloping Yard
    bmoreswim's Avatar
    Jul 2012
    Central MD
    4,233
    Generally agree with the above. Our cover is 5 years old and should last 10 years also. It has failed to open once in 5 years. A failed fancy internet switch I never used the features of. Replaced with a regular switch. It can be manually opened with a breaker bar and socket, which I did while I troubleshot the issue.
    They can be expensive to repair if it is needed. Really like a car. Usually good but there could be an issue. And you will need to replace the fabric at some point. A varmint has chewed a hole the last two years in the same place. So had to patch. I recommend a Dolphin robot for your debris. We have very little though.
    But the pool can be completely secured if needed. Think teens, neighbors, etc. No liability if covered and a cover pump is on it to pump off rain so a wee one couldn’t crawl on and drown in the water that would pool around them.
    18'x38' Rectangle (3'-8 1/2' deep w/ diving board) - 27K gal. w/ gray plaster
    Hayward equipment (cartridge filter, 2-speed pump, SWCG, automation) View Our Build
    Coverstar automatic pool cover | StoneMakers concrete retaining wall and decking | Merlin SmartMesh winter safety cover
    Spring 2013 Build | Dolphin Active 20 robot cleaner | Support TFP!
    With numerous walnut trees around our pool, I couldn't imagine not having the cover. It has been well worth the money over the years.
    Kayak Pool - 12 ft. x 24 ft. rectangular, 5˝ ft. deep end
    Frog System, Sta-Rite-Modular Media Cartridge Filter, Pentair 1 H.P. pump
    AquaPRO Pro500 heat pump & Automatic AutoGuard™ Pool safety cover
    BMK's Avatar
    Mar 2016
    Pittsburgh, PA
    188
    Our previous pool (came with the house) had an auto cover and it was great. It's a wooded area, and I can't imagine not having it. It also kept the heat in, chemical consumption down, we rarely had to vacuum or empty skimmers. Some municipalities, such as ours, even wave the fence requirement with the proper auto cover. It provides a better barrier to the water and as it was explained to me, "anyone can get on the other side of a fence if they really want to."
    They do require some routine maintenance but nothing difficult or time consuming. If you can swing it, I would highly recommend it. Because of the size and shape of our new pool, an auto cover just isn't in the budget. Unfortunately, I know what I'll be missing.
    44K gal freeform / padded vinyl and concrete /double waterfall and integrated slide/ Tan deck w/ 2 bubblers / Sta-rite PLM300 filter
    Pentair Intelleflo 3hp VS circ. pump, Whisperflo 5hp waterfall and 2hp slide pumps / Intellichlor IC60 SWG
    Heatsiphon 7.50hp pool heater/ Pentair automation w/ screenlogic / Dolphin S200 / TF100
