I have an older pool, large with funky things.
I can get counts on return jets, but the layout has a single pump for pool and spa. A second pump for water feature (which I don't really think is necessary).
I bought some gauges to tap into pump and estimate head loss.
Big thing is that lines to and from the pad are 1.5". At the pad is a mix of 2 and 1.5"
Existing North Star is ok, it leaks. It's loud. I think a 1.5 full rated motor would be fine. Just not sure about the spa.
Regardless, I have a 2HP now. I think the spa has 4 jets.
I have on the table:
Pentair is listed due to automation and heater.
I've looked at the spreadsheets from losing your head, but I ran out of duct tape for my head.
- SuperFlo 2 HP Dual Speed, Single Phase Pump - 340044
- Run low speed unless in spa mode - $$$
- Pentair SuperFlo VS - 1.5HP Single Phase - 342001 115/230v
- More speed options, don't have the peak 2HP -- $$$
- Pentair 011018 IntelliFlo 3HP Variable Speed Pool Pump Ultra Energy-Efficient, 230V
- Kitchen sink and most expensive $$$$$
