Plumbing a 25k gallon pool. Where to split things off?
Dec 19, 2017
15
Culpeper, VA
See sig for the pool I want to build. I have some questions about the plumbing:
#1: For the SUCTIONS (one side and 2 skimmers): Do I want to plumb the 2 skimmers to each other, or does each skimmer need a single solitary run back to the pad where the pump is?
#2: For the DISCHARGE (2 waterfalls and 2 to 3 return jets): Do I need to run individual PVC pipes from the pump discharge to each waterfall, or can I run one line from the pump to the first waterfall, and split off there to go to the next waterfall?
#3: Where should I put valves? Obviously on the discharge side to turn the waterfalls on and off. BUT, I DON'T want to make it possible that I shut off all places for the pump to suck water from.
#4: Does anyone have a "pool plumbing 101 guide"? I have worked with plenty of PVC. I am a former Navy Nuke. If I can open, repair, and reseal a seawater system, and water doesn't leak in at test depth, I can handle this job. I just need some guidance.
#1 I suggest all runs be homeruns back to the pad
#2 You should have each water feature its own adjustable run as it will be near impossible to balance them the way you suggest.
#3 See below picture for my setup
idxHq4RhUd0QG8Ax8DkXqlrGIx9oHM21EYc3qjE72dfvR6oN-OAv9WYg_LsabEWeU5dDzQSqkf1eoaUF85yQOxJJitz6yMESMsSR7_lYQQ9TiONhwrhXaAlirJj2v4tYi53U3Kj5wRVi_D8r3-BfdvRH-PPt2OdeOYUdD_7v5_qvnkpINVTtSdRWfblrLW9_fce095CdDMcK9-zPAClPVyC5NCF1PUkHUo-Ck4jfBH38yy8fvmVXEexJLF1-8MIUseBVMnAqdWfdp1X53fJB8szBnZN646CmjC9Yneya3daNn8DuxvIur4Kh3B5kM-m0Bq1JCvr4byiggVSBwba2RyVnG5PLeCRw3t24Yg-4ueRf_co_6vK0yKrjXAlEsMdqISCQx9wXlPgfQjxSihhUeu2t1gbMeaFc1CJTekwXSiMjTAZZsoPPw0VDuClB4FbwULw-D9Dlciq1de1gTUf4wSfnor01Tiq1yiGgLrPhHhi9b5haC23jKqhA7NWF7yvzt9-YwVJ4yhyvImgb0ArKq4SV2kGzV20-kHu5z3kPZObI4qDHExAF582LHedX_H908DslGoOA7-vlKig7d8Aq4Ju3COFMZ4GNrME224_X6AGqe-FxWN_-SZUp_wEnwDPM4b1vHoV9jTqDSCZRKCh55JfO3joVpKHM=w1705-h959-no
