Results 1 to 13 of 13
Thread: Is my wife right?
    jobybett's Avatar
    Mar 2017
    Mission Viejo, CA
    93
    Is my wife right?
    So, we moved to the house a little over a year ago, so far Iíve replaced the pump, added SWCG and replaced the automation.
    But my pipes are a mess (to me) and I really think ripping it all out, putting down a proper concrete pad and spacing it all out a little would be well worth it. The driver being that I forgot to add a check valve between the heater and SWCG.
    My wife thinks Iím nuts and should just leave it alone...
    Is she right?
    22,000 gal IG pebletech with raised IG spillover spa, test Kit: Taylor K2006
    Pump - Pentair Inteliflo 2 VST
    Heater - Pentair Master Temp 250, Filter - Pentair FNSP 60 DE
    Automation - Jandy iAquaLink 2.0 RS8
    SWCG - Jandy AquaPure PLC1400 Robot "Dora" the Dolphin A30i
    Mod Squad kimkats's Avatar
    Jul 2012
    Tallahassee, FL
    35,022
    Re: Is my wife right?
    NOOOOOO don't make me say it...........................us wives have to stick together................................shhhhhhhhhhhhhh don't tell her I said this but............you are right. It needs to be redone
    Mod Squad Jimrahbe's Avatar
    Jul 2014
    Bedford, TX
    9,854
    jb,
    The short answer is yes... She is right....
    While you always want a check valve between a 3" tab dispenser and a heater, this is just not necessary for a SWCG...
    Unlike a tab dispenser the SWCG will not produce chlorine when off.
    So, it looks like you will have to come up with a better 'excuse' for your equipment pad upgrade.
    Thanks for posting,
    Mod Squad mknauss's Avatar
    May 2014
    Laughlin, NV
    11,793
    Hmmmm - that is a consensus answer!!!
    6000 Gallon IG Fiberglass with integrated Spa;Pentair CCP240 Cartridge Filter with Pentair Intelliflo VS Pump and HTR250 heater. IC40 SWG. EasyTouch 4. Dolphin Active20 Robot "Roadrunner", TF 100 Test Kit w/SpeedStir!
    CLICK HERE to Become a TroubleFreePool.com Supporter!! Pool Math App
    Marty
    Jul 2014
    Bedford, TX
    9,854
    Quote Originally Posted by mknauss View Post
    Marty,
    My understanding is that what damages a heater is the acid in the tablets flowing back into the heater causing really low pH... This is something that does not happen with a SWCG.
    Besides.. the wife is 'always' right...
    May 2014
    Laughlin, NV
    11,793
    I was commenting on Kim saying he was right and you saying she was right!!
    I agree - no check valve is needed with a SWCG.
    So I will say -- SHE is right!
    Marty
    Jan 2012
    'burbs of Augusta, Georgia
    8,855
    Yes.
    oh wait....was there another question here?? I was just answering the topic line... lol
    As to the work in question- as long as you're not asking *her* to do it....what diff does it make? Just tell her you'll feel better with the equipment spaced out a bit. Do it if it makes you happy.
    Maddie
    Skippy's Pool Cooler --> Skippy's New Fountain Our Build --> Our Pool Solved Our Sloping Yard
    JoyfulNoise's Avatar
    May 2015
    14,225
    Thereís a thread over at Trouble Free Wives forum about whether or not they are right by default....the forum is on the dark web and I canít share the IP address on the public internet. If you want access youíll need to install special blockchain encryption software (similar to how Bitcoin operates) and fork over some serious cash to join.
    Load up the Confide App on your phone and send me a self-destructing message if youíre interested....
    Matt
    jobybett's Avatar
    Mar 2017
    Mission Viejo, CA
    93
    Quote Originally Posted by YippeeSkippy View Post
    It means I get to work on other "more important" honey do's around the house
    Thanks guys for the input, glad I don't NEED to put in the extra check valve, as you can see there is no room...
    Jan 2012
    8,855
    Quote Originally Posted by jobybett View Post
    <ouch!> my head hurts! LOL
    M.
    sktn77a's Avatar
    Chapel Hill, NC
    736
    You don't need to do it. But if you want to do it, I'd wait until something happens that needs cutting into the plumbing and do it then. A happy wife is a happy life!
    Keith
    15,000 gallon in-ground gunite/plaster pool, 1.5" PVC plumbing
    1.0HP Sta-Rite DuraGlass P2R pump, Hayward S244T sand filter
    Teledyne-Laars Lite-2 250k heater, Hayward CL200 chlorinator
    Polaris 380/Hayward 6060 booster pump
    Jun 2014
    17,812
    Valentine's Day was yesterday. Now you can do whatever you want.
    needsajet's Avatar
    Jan 2016
    Sydney, NSW, Australia
    4,541
    Pat, that's a belly laugh, that!
    I wouldn't touch it until it needs something. But if you need an excuse, you can always say that the internet pajama people said so.
    12k IG salt; glass beads in plaster; K-2006C, K-1766, K-1106 and CCL test kits; Pentair Eco800 1.2HP VS; Zodiac SWCG 1.3 lb/day (25 g/hr); 25" filter recycled glass; OKU solar panels; 1/2 HP solar pump; Rebel (Warrior) pool cleaner; FlowViz; Other family pools 10K SWCG and 15K on liquid; PoolMath app subscriber; | Tips for New Members to get the best possible advice | ... and this helped me a lot!: TFPC for Beginners
