Thread: Flocculant Question
    Feb 2018
    Goodyear
    1
    Flocculant Question
    So I screwed up. Been a while since i had a pool. I treated my pool with flock and it has cartridge filters. That being said is there any chemical i can use to clean it out of the filters?
    JoyfulNoise's Avatar
    May 2015
    14,225
    Re: Flocculant Question
    You can try to soak the filter first on a solution of trisodium phosphate (TSP can be found in hardware stores in the paint section just make sure it’s REAL TSP and not some “eco-friendly” knock off). After soaking the carts for a few hours you can then rinse them and give it a try.
    There’s a good chance your cartridges are hosed so I’d set your expectations low and be prepared to buy new ones.
    Matt
