Results 1 to 17 of 17
Thread: Pentair Master Temp 250 time to replace?
    jobybett's Avatar
    Mar 2017
    Mission Viejo, CA
    93
    Hi,
    Went to turn on the spa last night (first time in about 4 months) and the heater won't heat. I see the 128 R=8 on the panel, the fan kicks in as usual, but no heat. After about 1 min the service light comes on, and that's that.
    The heater is 9 years old, we moved into this house a year ago, so have no idea of its service or usage history. Last summer we did not use it to heat the 22k IG pool, just the IG spa, as and when we wanted to use it.
    So my question, should I spend some $$ on getting someone to look at it, or at 9 years should I call it quits and look at a new unit? I'm not a fan on spending money on something that's gonna need replacing soon anyway, I know without looking at it, it's an impossible question, but is it likely I could get 2 or 3 more years out of it?
    22,000 gal IG pebletech with raised IG spillover spa, test Kit: Taylor K2006
    Pump - Pentair Inteliflo 2 VST
    Heater - Pentair Master Temp 250, Filter - Pentair FNSP 60 DE
    Automation - Jandy iAquaLink 2.0 RS8
    SWCG - Jandy AquaPure PLC1400 Robot "Dora" the Dolphin A30i
    Re: Pentair Master Temp 250 time to replace?
    Check whether any of the red diagnostic LEDís on back of board (AGS, AFS, SFS, HLS or PS) are on.
    Are there any error codes?
    I suspect that it's going to be a an air flow switch issue or an igniter issue.
    Do you smell gas during the startup attempt?
    Support the site
    jobybett's Avatar
    Mar 2017
    Mission Viejo, CA
    93
    Quote Originally Posted by JamesW View Post
    Nope no smell of gas, looks like the AGS led is on
    ps0303's Avatar
    Jul 2011
    FL
    3,944
    Sounds like it is erroring out before it tries any of the real startup processing.
    The AGS sensor is on the right side of the header. It is the side where only one sensor is located. Now that error LED can be a trick as well. I have seen bad boards throw that error out. You can try to bypass that sensor with a jumper wire and see what happens.
    Paul
    Gastek Pool & Gas Services If you would like to provide a review of the help I provided, please use the following link to leave a review. Gastek Google review,
    Check out some videos on my YouTube channel - Gastekservices on YouTube
    You can test the AGS with a multimeter. If it shows open, then it's bad.
    Support the site
    jobybett's Avatar
    Mar 2017
    Mission Viejo, CA
    93
    Assuming this is the right sensor, yes itís open
    Yes, just replace the AGS switch.
    Support the site
    jobybett's Avatar
    Mar 2017
    Mission Viejo, CA
    93
    Thanks for the help guys!!
    Last question, would you stick with a 250 or go up to a 300 or 350? Given itís really only used to heat an IG spar thatís about 6í diameter and 4í deep
    Mod Squad mknauss's Avatar
    May 2014
    Laughlin, NV
    11,793
    I believe you only need to replace the sensor ------
    6000 Gallon IG Fiberglass with integrated Spa;Pentair CCP240 Cartridge Filter with Pentair Intelliflo VS Pump and HTR250 heater. IC40 SWG. EasyTouch 4. Dolphin Active20 Robot "Roadrunner", TF 100 Test Kit w/SpeedStir!
    CLICK HERE to Become a TroubleFreePool.com Supporter!! Pool Math App
    Marty
    250 should be good for a spa. If you wanted to upsize, you would have to make sure that the gas line and meter are big enough.
    All you should need now is the AGS switch.
    You can temporarily connect the two wires together that go to the switch to see if the heater fires. Don't leave them connected.
    Make sure that you have good flow and only let the heater run for a few seconds.
    Don't run the heater with a bypassed switch for normal operation.
    Support the site
    jobybett's Avatar
    Mar 2017
    Mission Viejo, CA
    93
    Ok so I secretly wanted a new one, but you are 100% right, bypassed the sensor and she fired up perfectly hot air coming out of the exhaust. Only ran it a few seconds, as you said.
    Thanks so much!! Iíll replace the sensor and see how long I can keep it going.
    Thanks again guys!!!
    Cool. Good job.
    Support the site
    Pool Clown's Avatar
    Sep 2008
    Silicon Valley, CA
    1,791
    Quote Originally Posted by jobybett View Post
    Last question, would you stick with a 250 or go up to a 300 or 350? Given it’s really only used to heat an IG spar that’s about 6’ diameter and 4’ deep
    Upgrading is going to give you quicker heat up times and a bit of gas savings (you may, or may not notice on your gas bill). And as stated earlier, you would need the appropriate size gas line for the increased gas requirement.
    Factory Warranty Station for:
    Jandy/Zodiac, Pentair, Sta-Rite, Raypak (Rheem, Rudd), Polaris,
    jobybett's Avatar
    Mar 2017
    Mission Viejo, CA
    93
    Thanks PC, I think I will upsize a little when the time comes.
    New AGS comes tomorrow, is there anything special I need to know about replacing it? Or is it just as simple as it looks? Wires off, unscrew, screw in wires on....
    That's about all there is to it. Turn off the pump and remove the heater drain plug.
    The AGS comes with Teflon tape on the threads but you might want to put a few extra wraps for a good seal. It should go in snug but don't over tighten.
    Reinstall the drain plug and start the pump.
    Wait a few minutes then start the heater.
    Support the site
    jobybett's Avatar
    Mar 2017
    Mission Viejo, CA
    93
    Again big thanks guys!! New AGS is in and its working great!!
    On a side note, while the side was open I found a nice critter nest in there (Rat, squirrel, something else) so cleaned it all out, there is a bit of gnawing on wires, but noting serious, hahaha
    Good job.
    Support the site
