Hello,
I've had this SPD for awhile and finally have time to install it w 20amp DP breaker.
The install of the wiring is very clear, but for some reason I thought my (2) 200amp service panels sides were accessible. Unfortunately the panels are flush mounted to the sheetrock.
Based on the picture of the SPD, an HEPD80, it's easiest way to install is directly into a punch-out and be done w it. But, there are 2 green lights that must be viewed to indicate it's working, so it cannot be covered.
I have a few ideas, but wanted to know if anyone has installed one of these before w a flush panel, had no wires exposed and made the install look visually appealing. All of our garages in our gated-community are sheet rocked, painted and trimmed out, so installs had to look good, as well as to code.
Thank you and pls let me know if you have any questions,
tstex
tstex
