good Morning everyone,
quick question, I believe i have decided on pool equipment..mostly
pump Pentair VSF
filter sand filter Triton II TR 60
I was pretty sure I was going with a SWG, the guy at E Konomy Pool supply in Tucson, suggested I go with a different type of tablet, AquaFinesse ? I found a thread on here with people using AquaFinesse for spas
also, I have no water features, on the suction side, what do you suggest, I was thinking a two valve "T" system, one for floor drains and one for skimmer/kreepy krawler?
the plumber I am considering using has suggested a 3 way valve?
My thought with the two valve system would be, I could use the two valve system obviously in tandem, 25% skimmer/75% floor drain or something like that. If I happen to have alot of skimming needs, I could go out change the valves and "skim like crazy" to help clean. then return to normal.
can i achieve the same process with a 3 way valve? the big issue is I may not know the true function of a three way valve?
I'm no expert here, for sure, but I'll give you some random thoughts that you should consider or check on.
Yay for VS pump! I love mine. But I just read here, somewhere, a caution about variable
flow pumps vs variable
speed pumps. (Maybe the VSF is both? Not sure.) Anyway, the warning was: while variable flow sounds good, and solves for figuring out that important component of a pool plumbing system (flow rate), some variable flow pumps will push, however much, to achieve the desired flow. Push no matter what. So if your system develops a problem with flow (obstruction, filter problem, whatever) the pump won't know about it, and push more and more to reach it's goal. Something like that. The wisdom was to go with variable speed instead, and calculate or measure for flow. (I have a flow meter in my system, so I know exactly what's happening, flow-wise, all the time.) I also read a note that VF pumps can't be used with a solar heating system. Check all that out before you buy.
I think the consensus here is SWG (those who have them swear by them), and certainly not tabs (except
maybe for specific, limited use). My personal opinion is: tabs are the devil and I'll never put another one in my pool. Go to Pool School, as Marty suggests, and sanitize your water the TFP way. And that would be my over-arching advice. Trust TFP explicitly. You can safely ignore advice from
any other pool professional. Don't mix'n'match advice from multiple sources. Don't interpolate or modify TFP's advice. Just follow it. And run all your equipment decisions by someone here, just as you are doing. (So you're already on the right track!)
OK, I'm not a pool builder or hydraulic guy (though there are some here that are, who hopefully will weigh in), but I can share with you what worked for me on my pool (which is the limit of my experience and knowledge). Again, just throwin' it out there, see what others think.
A three-way valve is like a controllable T. Three ports, three pipes connect to it. You can mix two into one, or divert one into either or both.
I
had pool drains that were plumbed to the skimmer. And I have a three-way valve that is used to control how much water my VS pump draws from either the skimmer or the vacuum port or a mix of the two.
A drain set up like mine can control the flow through the drains by tweaking a gizmo in the skimmer (a diverter plate) that balances how much water is drawn from the drains vs the skimmer. But my pool didn't have a diverter installed, so all my water was being drawn from the skimmer (the path of least resistance) and none from the drains. My pool circulated fine without the drains involved. So, at the advice of the guy that replaced my plaster, I deleted the drains! Yep, I have no main drains. There are some circulation considerations to that that need to be addressed before you get excited by that idea, but I
love not having any. Pool looks way better without them, they don't stub toes or hang up my vacuum or brushing. And the biggie for me: while main drains have been improved over the years to make them more safe (from entanglement), they are still not 100% safe. Know what drain is 100% safe? No drain! So if a pool circulation system is designed correctly (how many returns and where they are placed and how they are directed), you don't actually need a main drain, and I understand that is becoming more common in new pool builds. Drains are rarely (if ever) used to actually drain a pool (a portable pump is used for that), so no loss there. Drains are primarily for circulation or cleaning (old school), but there are better ways to do both. You have to check your codes, though, as some municipalities still require them.
OK, the three way. So theoretically, I could use my three-way valve, along with my VS pump, to balance how much water was being drawn from the skimmer and the vacuum, to optimize the performance of each. Problem was, I couldn't get that to work in my pool. The only way I could get enough flow through both, to run the vacuum and clear my surface of leaves, was to goose the VS pump so high as to use a ridiculous amount of watts. So I ended up adding an actuator to my three-way valve! My EasyTouch automation unit turns the valve to either skimmer or vacuum (but not both) according to a schedule, and then adjusts the pump speed to optimize the performance of each. All automatic. I get 100% flow to each (separately), and so can run the pump at the minimum speed to achieve results. It all works great.
Regarding "go out to adjust the valve"... I don't have to "go out" to do anything. My EasyTouch can do all that, automatically or I can control everything manually from my iPhone, iPad, computer or wall unit, while home or away. Are you considering automation? Something to think about. I can schedule how much vacuuming per day, how much skimming, etc. Or I can push a button and do either, on the fly (like to do some extra cleaning before guests arrive, or after a storm, whatever). I even have a "high-speed skim" mode that I can run for a half hour or so, that I can fire up (manually or automatically) whenever I want to "polish" the surface up quickly. The ET then shuts down the high-speed mode automatically, after a pre-determined length of time. The ET moves valves and adjusts the pump for you, for whatever you want to do. Automation can control all those things and more (spas, SWG, features, lights, etc, etc).
If you're going with Pentair, read up on automation, or ask about it here. If you think you might go that way, check back in. I ended up with the wrong version of EasyTouch and am sorry for it. I actually would have been happier with a different model. There are a lot of them, and they have different capabilities that need to be considered before a purchase. Unlike me, don't rely on a recommendation from your PB, make sure you know what you need and what you are getting. TFP can help with all that.
There, that'll keep you busy for a while!
Oops, forgot to add. There's a large number here who love robots for cleaning. So that takes vacuuming out of the plumbing equation all together. Something else for you to consider. That said, if it were me, I'd be tempted to plumb for a vacuum anyway, so that you could have that option. You can't add that later!!
