I have a pool with spa that spills over into the pool and it has a waterfall feature. In Nashville, Tn it is starting to drop to freezing and it seem crazy to have that waterfall running out there in freeze mode. I would like to know if it is possible to winterize just the water feature while leaving the rest of the system running. The previous owners ran all of the pumps, all of the time, all year long.
The waterfall pump is it's own system and does not filter through the main pools filter. It feeds from a drain in the bottom of the pool. In the first picture the waterfall is the pipe with the clear container on top of it. In the second photo you can see the pump and it has a grey valve on the input to the pump. Why would there need to be a valve there? The ultimate goal would be to winterize the waterfall and then I could turn the freeze protection off for it. If I need to move the entire pump inside I could probably do that as well.
