So this is the first time I've needed to close a pool (just bought the house late summer). TFP has been great so far and the pool is in great shape (other than an absurd amount of leaves). It's still hovering around 68 degrees even though it's mid October, somehow, so I've got a little time left to plan.
1. Vacuum/sweep, etc, get it nice and clean.
2. Add bleach/use SWG to shock level, let it drift down a little.
3. Add polyquat startup dose (I guess I'll get this online and figure out how much I need)
4. Get out my cover (mesh safety cover with the brass things, I need to make sure I can find them all, some are out).
5. Use main drain to drain 4 inches below the returns. These are about 12 inches below my tile, so I'll be about 16 inches below tile, is that fine?
6. Remove skimmer baskets.
7. Using my shop vac, close shallow skimmer and the main drain, blow into deep skimmer and out the return until basically dry. How do I atttach the shop vac to the skimmer tightly? Then shut off that skimmer, do the other skimmer. Shut off both skimmers. Then how do I blow out the main drain? Do I need to remove the SWG? If I remove it do I need to cap both ends, or put in a blank? Do I drain the filter at all? When I'm blowing out the returns and skimmers do I turn the multiport to recirculate instead of filter?
8. Remove drain plugs in filter and heater.
9. Is anti-freeze necessary? Personal decision? If so, where do I need to add it?
10. I need some expandable rubber plugs for the two returns, and maybe the SWG unions? What size are returns normally? Like 1/2" PVC? 3/4"? Can I just get these at the hardware store?
11. Put Gizzmos in the skimmers (already have a couple I think)
12. Put the cover on and tighten it or whatever. I'll figure this out I'm sure.
13. Put the automatic pump on the cover, just toss it into the middle?
I also have a pressure side cleaner thing that I've never used. I guess I need to blow out and drain this too?
Do I need to backwash the filter or anything? Or can it wait until spring to get it nice and clean when opening?
I think of all the parts of the pool ownership, the closing is the most concerning to me. I really don't want to break something expensive and underground.
I've attached a picture of my pool house and equipment and one (bad) drawing of the layout, in case that helps.
Thanks.
Thanks.
