HI, I am new to doing my own chemicals rather than the pool store's.
Question: My CYA is at 100. My chlorine depletes frequently. My well water has high TA and low pH. The pool is scheduled to be closed next week. So my concern is that if I drain some water and replace it w/ well water to reduce my CYA, my TA will skyrocket (always does), and my pH will be low - this is a constant problem for me. I don't think I'll have time to adjust the TA and pH to good levels before closing.
1) Is it ok to leave the CYA at 100 for the winter (Northern Indiana)?
2) Also, my cc is around .5. Will adding bleach to shock levels before closing take care of that? I've not added bleach to shock levels yet (just ran out of the ps shock tx).
Thank you!
Thank you!
