The only way to increase the skimming action in the pool is to:
A. increase the velocity or flow over the weir. (It doesn't do that)
B. Improve the surface circulation within the pool. (Doesn't do that either)
Improving circulation or altering action that only takes place within the skimmer box, does nothing outside the skimmer in the pool. I see no way this device can be of much value beyond serving as a handle on the basket.
It certainly isn't going to have an affect on "surface tension" or "gravitational pull" outside the skimmer box. And "blocking the lower depth of water and forcing the water to fall over the top, greater energy is being created in the pull of the very top layer of water." is actually a perfect description of precisely what the weir does.
I also noticed there are some additional steps to remove the debris. Seems like just dumping the debris or removing a sock is easier & quicker. Just my $.02
