Algae has never been a problem as I have kept on top of my chemicals ( hardest to do in summer in AZ). Only time (5 years ago) I had "green" algae was when my salt cell had blown a fuse and that only lasted less than a day. I'm getting these brownish dots in various areas in my pool which are fairly easy to rub away with pumice stone or similar. They're areas which get a lot of direct sunlight and once I get rid of them in an area, they do not come back there. The spa, which is slightly raised up in a corner and has a lot more shade than any other part of pool, has never had these spots.) I have never had these spots until this year, pool WAS drained and refilled early in year. Biggest area has been about a square foot (never more than that) and usually much less. I've kept my chlorine level slightly higher than normal for about 10 days now. Weather here has been extreme for that time even here in AZ. (110 degrees+ , with a few 117+thrown in there, for 10 straight days, at least). How can I be sure what exactly it is and does it sound like black algae ? My basic numbers are as follows;
FAC = 7.0
TAC = 7.0
SALT = 4000ppm
CYA ppm= 80
TA ppm= 100
pH = 7.8
Copper ppm= 0
Iron ppm= 0
Phosphates ppb = 90
Calcium Hardness = 250
FAC = 7.0
TAC = 7.0
SALT = 4000ppm
CYA ppm= 80
TA ppm= 100
pH = 7.8
Copper ppm= 0
Iron ppm= 0
Phosphates ppb = 90
