Results 1 to 7 of 7
Thread: Trouble Keeping Chlorine Levels Up
  1. Back To Top    #1
    Join Date
    May 2017
    Location
    Englishtown/NJ
    Posts
    4
    I'm new to this site and also a first time pool owner. After having a really frustrating experience with the local pool stores, I came across this site and decided to take the matters into my own hands. After opening up my pool for the first time this season, the water was cloudy with some visible algae. The CYA level was at 120. I drained 50% of the water and re-filled it from tap.
    I have a 20,000 gallon vinyl Non-SWCG in-ground pool. I also purchased the TF-100 test kit.
    After the initial re-fill and the SLAM process I got my numbers to:
    FC = 4.5
    PH = 7.8
    TA = 130
    CH = 200
    CYA = 40
    I was able to maintain it for about a week at the appropriate levels, but now that the temperatures are starting to climb up (in the 90s), it seems like I'm losing most of the chlorine over night. I've been trying to bring the FC level to at least a 5. I add 10% liquid chlorine from Walmart based on the pool math calculator numbers, but when I check the levels, the FC hardly makes it to 1.5. I'm also seeing a slight drop in other numbers:
    This morning test results:
    FC = 1
    PH= 7.5
    TA = 90
    CH = 150
    CYA 40
    The pool looks great with no signs of algae, so far... What could be causing the chlorine to drop? I'll greatly appreciate any suggestions on how to move forward!
    Thanks in advance.
  2. Back To Top    #2
    AftonJeeper's Avatar
    Join Date
    May 2017
    Location
    Twin Cities, MN
    Posts
    1,147
    Re: Trouble Keeping Chlorine Levels Up
    Sever factors could be causing it. The size of your pool may be off which would explain why you can't get to the FC number your shooting for. Algae could be starting causing the increased demand for chlorine. Chlorine could be old and ineffective, check the date code. IIRC the first 2 numbers are the year and the next set of numbers are the day it left the factory. 17 170 would be today.
    20'x48' 40,000 gal. Vinyl, Pentair Intelliflo 2 VST, Sta-Rite PLM300 System 2 Cartridge Filter, and a Pentair Mastertemp 250 heater all controlled by Pentair Easy Touch with Screen Logic. Dolphin Premier pool attendant.
    I've got iron stained well water. TF-100 and Speed Stir, Lamotte 3017-G for Borates
  3. Back To Top    #3
    pookiesunshine's Avatar
    Join Date
    May 2016
    Location
    Cincinnati, OH
    Posts
    435
    Quote Originally Posted by AftonJeeper View Post
    .... Chlorine could be old and ineffective, check the date code. IIRC the first 2 numbers are the year and the next set of numbers are the day it left the factory. 17 170 would be today.
    somebody else reported they got some old chlorine. when you pour it into the pool, does it smell strong? look pale yellow? yes i know this is subjective....
    30000 gal inground vinyl liner;sand filter w/glass media, nuvo uv, TF-100 test kit; 25 years on Baquacil, converted to TFP chlorine in 2016
  4. Back To Top    #4
    Razorhog's Avatar
    Join Date
    Jun 2013
    Location
    Northeast Arkansas
    Posts
    483
    You might try getting a few jugs of regular great value bleach and see if your FC responds differently. After adding wait 20-30 minutes for it to circulate and test to see if you hit your target. If not, I would suspect algae.
    SLAM * Chlorine/CYA Chart * Pool Math * Pool School
    17.5k gal IG Fiberglass, Triton II TR60 Sand Filter, Jacuzzi Magum Force Pump 1.5 hp, 3/4 hp booster, Polaris 280, TF-100 Test Kit with Speed Stir
  5. Back To Top    #5
    Join Date
    May 2017
    Location
    Englishtown/NJ
    Posts
    4
    Thanks for the pointers! I never did calculate the size and only relied on the number given by the pool store that they had on record, I assume from the previous owner. Will check the dates too.
  6. Back To Top    #6
    Join Date
    May 2017
    Location
    Englishtown/NJ
    Posts
    4
    Quote Originally Posted by pookiesunshine View Post
    Thanks for your reply! It doesn't have strong smell at all, but looks a bit yellowish.. I'm storing it in the garage that does get pretty hot during the day.. now I'm thinking that could be the reason..
  7. Back To Top    #7
    Join Date
    May 2017
    Location
    Englishtown/NJ
    Posts
    4
    Quote Originally Posted by Razorhog View Post
    Thanks, yes will give it a shot.
Posting Permissions
  • You may not post replies
  • You may not edit your posts
