Results 1 to 10 of 10
Thread: using fas-dpd for first time is this ok?
    May 2009
    Jasper, TN
    249
    Using the fas-dpd and CYA test from tftestkits and PH and Alk from another kit, I get:
    FC = 2.5
    CC = 0
    CYA = 45
    ALK = 90
    PH = 7.6 (non tftestkit, reading color chart it's 7.6 to 7.8 at the most).
    I could not get the full tftestkit right now so I bought the tests and used the instructions from their website. So once I got a FC of 2.5 (5 drops), I added 5 drops of R-0003 (swirling between drops) and there was no color change. So I take that to mean there are 0 CC's?
    24' x 52" AGP = 13.5k gallons
    Dynamo 2.0 HP pump,Sand Dollar sand filter
    Polaris 65 vacuum (good when there are a ton of leaves on bottom), Pool Rover Jr. (LOVE it, but power box dead right now), AquaCritter (an excellent suction side cleaner)
    Re: using fas-dpd for first time is this ok?
    Yes, that all sounds correct.
    With a CYA of 45 you want to maintain an FC level of at least 4 at all times.
    May 2009
    Jasper, TN
    249
    To be 100% sure, I only need to shock if I ever get CC's?
    Or will I ever need to shock if CC=0?
    You will only need to worry about shock if your water looks cloudy or measures .5ppm or more. With CC of 0 there is no need but to maintain proper chlorine level.
    27' round AG vinyl, 54" height with 18,200 gallons of water.
    1HP pump, 150lb sand filter run 12-14 per day. Using 12.5% liquid chlorine. BBB method.
    Taylor K-2006 test kit. Lamotte strips for borate at 50ppm.
    Goals: CYA-40, TA-80, FC-4, CC-0, Borate-50, PH-7.4-7.8 with use of fountain.
    May 2009
    Jasper, TN
    249
    Ok, thanks for the replies.
    Just needing to make sure the pool is perfect for the weekend.
    If CC is 0 does that mean chlorine shouldn't fall at night?
    I know a check in the evening and the next morning is the way to check that, but just wanting to understand more of the background processes.
    frustratedpoolmom's Avatar
    SWSuburban Chicago, IL
    11,969
    No. A 0 CC reading is good but doesn't have any bearing on whether the chlorine will drop at night. Hopefully yours held?
    So you got 2.5, and you should have at least 4 at all times (as Jason advised). You should have added enough bleach to reach 6 or 7, which should keep you above 4 until the next night when you test again. Make sense?
    reebok's Avatar
    Apr 2009
    Lakeland, FL
    1,268
    you shouldn't lose more than 1ppm of fc overnight. have you read pool school? it will help you understand things as a whole a lot better.
    May 2009
    Jasper, TN
    249
    yes I've read the pool school, but when you actually get your hands on something for the first time it still gets a little confusing. i've been testing since day one but not with fas-dpd so just a little different process than I been using.
    I didn't add any more bleach last night since it was dark, but this morning at around 7am it took 5 drops to turn clear so it held at 2.5 all night. I then bumped it up afterwards.
    Btw, will the amount of fas-dpd crystals affect the accuracy of the test? The instructions say a heaping scoop of crystals (using the blue scoop)... but a heaping scoop is not very precise. The scoop is so small it doesn't seem possible to have a rounded scoop full but a heaping pile that covers the flat area of the scoop too. So how 'off' will a test be if the 'heaping' scoop is a little more than intended?
    Apr 2009
    Sarasota Florida
    143
    Quote Originally Posted by rastoma
    I believe as long as it turns red and stays red you are fine. I do not believe it has much effect as long as it is red.
    Kidney shaped ~ 10000 gallon Ig Plaster pool with pool cage. 120sf Cartridge filter. Pentair WhisperFlo WFDS-26, 230 Volt, 7.8/3.0 Amp, 1-1/2 Horsepower 2 speed pump, Solar panels on the roof. Heliotrope HelioMatic 4000D solar controller.
    mdhwoods is correct. Extra powder, within reason, is fine.
