3 weeks ago I closed on a house for my family and it has our first pool. House was built in '79, so I assume the pool was built shortly thereafter. The plaster was redone "3-5 years ago." It looks great. Pool is clear, and other than some missing tiles and damaged coping, we are enjoying having it.
Leslie's has been testing my water and coaching me on chemicals, but every time I go in, I get a different answer as to what my strategy should be. (which is very frustrating)
This morning I order the TF-100.
My big issue is the CYA. One guy at Leslie's tells me I should pull out the tabs, and another guy tells me I should always have the tabs in. (my CYA is "well above 100") (FC is below 2, and ph is 7.6)
After reading up with you guys, I have pulled the tabs out, and I have some leftover CAL-HYPO SHOCK that I'm using to try and keep the chlorine the water. When that is gone, I will start using bleach.
I plan on trying to do a 40% drain this weekend to lower the CYA.
Advice, warnings, and encouragement are appreciated.
