Hello All. I have a pool leak and need some guidance on troubleshooting the location.
First my pool info: 16x32 gunite inground pool. One skimmer, one main drain. I realized I had a leak end of last year (having to add water daily) which the pool guy identified as the skimmer pipe. This spring we replaced the skimmer, and resurfaced the pool.
Upon opening, I was running the pump 24/7 (new plaster), and for a week it did not appear the pool was leaking and I did not need to add any water. Thought everything was great. Unfortunately, after transitioning to only running the pump 8-12 hours, I noticed the leak had returned as I was losing water (inch or so per day).
This tells me (based a lot of what I've learned here), since the pool I believe is leaking primarily with the equipment off that I likely have a suction side leak. I let the water get below the skimmer, but there is still water in my skimmer bucket (is this normal if I have a skimmer leak?). Other possibilities I guess are main drain or pool light leak, but the water did not drain out over the winter (I believe eliminates the main drain possibility).
Pool guy is coming back tomorrow, he has a theory since we replaced the skimmer/pipe early in April and it got cold right after (weird weather here in Michigan as always) the hydraulic cement might have not set properly or we had a small crack. I just wanted to try and be prepared with as much knowledge as possible.
Pics:
View attachment 61860View attachment 61861View attachment 61862
Pics:
