Sand changed on Saturday and it looked perfect - Takes 45 minutes to remove 300# of sand! I was glad to know the laterals swivel up so you can take that center tube out to finish the last of the sand. Only a few little specks of goo....Also the laterals had some gunk, but I took a toothpick and high pressure water to get it out. Added CYA last night and topped to 15ppm. I had to add approximately 7# of CYA so used three tube socks...it all dissolved by this morning with a little help. I'll wait for tonight to do the CYA test, top to 15ppm again and see how tomorrow tests.
We took longer on this conversion due to a 4 day get away and just working in the sand removal, etc. I'm excited about getting the water balanced. Then on to our hot tub...removing water today and adding new.
Thanks for all the support....I'm going to come up with a lessons learned paper!
