Hi Everyone! I'm back for another season after successfully turning my "pond" into a beautiful oasis last year....AND maintaining it that way! [emoji4] The pump is now up and running and I've run my first set of tests. Last year, we closed by bringing our FC to SLAM level and draining to a few inches below the skimmer. We've now refilled over a period of 10 days or so with both well water and ~3 inches of rain water.
The pool is blue and mostly clear, but certainly not "sparkly" like it was at close and there are still some leaves to fish out from the middle.
Here are my numbers:
FC 1.5
CC 0.5
pH 7.2
TA 40
CH 100
I ran out of reagent and didn't even have enough to do one single CYA test [emoji21] (I immediately ordered some so should have it by next week)
My questions:
1. I'm assuming because the clarity of the pool isn't up to par, I should SLAM to start, correct?
2. Can I SLAM based on my fall CYA reading of 40 from last year, or do I need to wait for a new reading? And if I need to wait, what should I be doing in the meantime?
3. Will the low TA affect anything during the SLAM, or do I just wait to adjust that when everything else is all set? I sat around 70-90 all last summer and never really had to touch it, so I'm surprised it's this low..?
I already have the bleach ready to go, I'm just not 100% sure where to start since I don't have a current CYA reading. Thoughts? What am I missing?
Thank you!
FC 1.5
CC 0.5
pH 7.2
TA 40
CH 100
My questions:
Thank you!
