Results 1 to 13 of 13
Thread: CYA not showing up!!!
    Whendee81's Avatar
    May 2016
    Tickfaw, La.
    17
    So this year we basically almost totally drained our pool and refilled. I started adding CYA so that I could start slamming (added 5lbs) last week like Thurs.When I test for CYA it's not showing up at all!!! Idk what's going on! My ph level was high (it was pink) over 8 so I today added Muratic Acid to lower to 7.6
    there is 0 FC And 0 CC
    Any suggestions????
    Any help is appreciated
    24' round, vinyl, sand pump
    PH- was over 8 added acid to lower to 7.6
    TA- 220
    CH- 10
    FC-0
    CC-0
    CYA- ???? Should be 40-50 since I added 5lbs!
    24' Round Above Ground (Vinyl), Hi-Flo 48 frame Pump, and a big Sand Filter!
    40,870
    Re: CYA not showing up!!!
    What volume did you have set for your pool in pool math when you calculated that you needed to add five pounds?
    domct203's Avatar
    Jun 2015
    CT
    3,896
    How did you add the CYA? Did you use the 'sock method'?
    Dom - TFP Guide
    Intex 18' X 48" Ultra Frame AGP 6700 gallons | Two Intex CS8110 SWG's | Hayward Pro Series 21" Sandfilter | Hayward 1.5HP Power Flo Matrix pump | Hayward Thru-wall Skimmer | Wanda the Whale | 72 sq ft of Sungrabber Solar Panels with Hayward GLC-2P-A | Taylor K2006 Test Kit, Sample Sizer & Speed Stir | Click Here To Become a TFP Supporter!
    Whendee81's Avatar
    May 2016
    Tickfaw, La.
    17
    Volume of pool water 15,200 of water
    yes i used the sock method.
    Jan 2017
    Monterrey, NL, Mexico
    492
    How old are your test reagents?
    7,500 gal Rectangular, Easytouch 8, Air+water temp sensors, Screenlogic2, IC40, intellibright5g color12v, Intelli pH, SD 70 filter w/Zeolit, Magicstream Laminars, waterfall. Raised Monolithic concrete lined with glass beads.
    In Sunny Monterrey,Mx!
    40,870
    CYA regent is pretty stable.
    That 5 pounds should have added 40ppm.
    I know you said this is mostly new water.
    Have you added any chlorine yet?
    I would add 10ppm of FC and then test the FC and CC after about 15 minutes and report back.
    Whendee81's Avatar
    May 2016
    Tickfaw, La.
    17
    I have added chlorine. Sunday I did and today my reading is zero.
    40,870
    And what were the FC and CC readings after you added chlorine?
    Are you aware that you are supposed to be adding chlorine everyday?
    Whendee81's Avatar
    May 2016
    Tickfaw, La.
    17
    Yes, but I didn't start slamming yet because of the cya not showing up. What would you guys do at this point?
    Aug 2013
    Arab, Alabama
    422
    Can you explain exactly how you are testing your CYA? Step by step please...you are using the k2006 or the tf-100, correct?
    40,870
    Also, add 10ppm of FC and test the FC and CC after 10-15 minutes and report back.
    Apr 2017
    Phoenix
    500
    Did you back wash your pool anytime after adding the CYA? If you did, that could have washed it out since it can get trapped in the filter until it fully dissolves?
    16,000 gallon in-ground pebble tec pool. Hayward SP3400VSP Eco-Star Pump, Pentair Triton 2 TR-100 sand filter, A&A 5-port in-floor pool cleaner, Pentair Intellibrite 5g color changing pool light, Polaris 965iQ Robotic Pool Cleaner, OG Pool Math Subscriber and most importantly a Taylor K-2006C test kit.
    Test Kits Compared
    | SLAM | Chlorine / CYA Chart |
    Aug 2013
    Arab, Alabama
    422
    Quote Originally Posted by spinPHD View Post
    Very good post...
