Thread: Opening pool
    Jun 2016
    Muncie indiana
    20
    Opening pool
    We opened our pool back up for the season 2 days ago. We had winter cover on it and the water was crystal clear. We started filling it that evening but had to stop for the night. I worked all day yesterday and hubs forgot to start the filling again so it just sat there. I get up this morning and start filling it back up and it's green, not surprised. Now its completely filled. Started the pump/filter up and poured in bleach. Heres my numbers.
    FC 15
    CC 0
    pH 8.0
    TA 200
    CH 260
    CYA ?
    I don't have cya because I ran out last season. I ordered some and will be here in 2 days. Last year I had really high cya due to previous owners using pucks. But we have drained about 1/4 of the pool for the winter.
    Can I do anything in the meantime? Like getting TA and ph down? Or should I wait till we have clear water again. I do have a stabilizer, algae guard, clarifier, ph plus from the pervious owners.
    12,500 gal, AG, Hayward Sand Filter and pump, Built in 2004, Taylor k-2006
    Richard320's Avatar
    Jan 2010
    San Dimas, CA (LA County)
    20,299
    Re: Opening pool
    You really can't do anything at the moment. The high FC interferes with the pH test and makes it read falsely high. If you try lowering it, you might end up too low. TA is the last thing you worry about after everything else is dialed in and you're bored. CH is just fine where it is.
    Let the FC drop below 10 and check pH and see if you need to add some acid or not. And certainly check the CYA level when the reagent arrives, so you can set the FC level properly.
    Jun 2016
    Muncie indiana
    20
    Re: Opening pool
    I now have crystal clear water again. I did the loss test and passed. I just tested our water and here are the results.
    FC 6
    CC 0
    pH 8.0
    TA 200
    CH 240
    CYA 60
    pH and TA seem high. I know my target FC is 7-9. Anything else?
    I also have a silly question that I can't remember from last year ( we only owned this pool for a couple months before closing for the season). Does our filter need to be turned to 'closed' when the pump isn't on? Or can it stay on filter?
    Richard320's Avatar
    Jan 2010
    20,299
    Re: Opening pool
    Target 7.2 on pH and let the TA lower naturally over time. Each time you add acid, you lower TA a little.
    Leave it on filter.
