Thread: quick question
    flyinokra's Avatar
    Apr 2015
    Hernando MS.
    20
    quick question
    For some reason my pool looks different this year than years past. After testing the last few days I just wanted some feedback. The pool is right on the verge of being clear but is still holding a little cloudy. I bumped it up to mustard algae shock just to see if that was what I was seeing in places on the bottom of the pool(yellowish brown when sweeping). No loss in the last 2 nights, but I have heard to many times "should have left it up a little longer"
    FC-34
    CC-0
    TA-90
    PH-7.3
    CYA-55
    salt-3200
    30K Gallon 40x20 IG vinyl liner
    1.5HP Hayward Super Pump, a 27" Hayward Pro sand filter and
    Aqua Rite T-15 SWG
    Mod Squad Jimrahbe's Avatar
    Jul 2014
    Bedford, TX
    9,246
    Re: quick question
    Fly,
    The instructions say...
    You are done when:
    • CC is 0.5 or lower;
    • You pass an OCLT (ie overnight FC loss test shows a loss of 1.0 ppm or less);
    • And the water is clear.
    You have to pass all three tests...
    See this.. https://www.troublefreepool.com/cont...tain-shockingl
    flyinokra's Avatar
    Apr 2015
    Hernando MS.
    20
    Re: quick question
    Well CC is less than.5 and it passed the OCLT but its not clear. I guess that was my question. I knew I had 2 of the 3 just wondering what could be keeping it cloudy?
    Aqua Rite T-15 SWG
    Richard320's Avatar
    Jan 2010
    San Dimas, CA (LA County)
    20,296
    Re: quick question
    Quote Originally Posted by flyinokra View Post
    Filtration and brushing. You need to get anything sitting on the floor and walls suspended so it can be filtered out. If the stuff settles into drifts, sneak up on it with a vacuum so it gets drawn in rather that pushed away by the current ahead of the vacuum. You can improve filtering by adding a little DE to your sand filter.
    May 2014
    Clarksburg, WV
    331
    Re: quick question
    When i opened my pool, all the numbers looked fine, but the pool was cloudy. A storm ripped my winter cover and most of the water on top went into the pool. Just nasty black water. I kept the numbers good for a few days. Bumped FC up to SLAM level. Had no CCs and the FC stayed high for about 4 days. Then and finally on the 5th day I woke up and the pool was crystal clear. Just took a few days to filter all the "junk" out of the water. FC stayed high for the next 4 or 5 days as well. I didnt have to do anything for about 5 days. Just let the FC fall to normal.
    Point is, it might take a few days to filter out all the stuff. Backwash regularly.
    24'x54" 15k AG round - Outback Genesis
    1 1/2hp Hayward Matrix 2 speed. Hayward 180T Sand Filter
    TF-100 Test Kit
    Pool School & TF-100
    How to SLAM
    flyinokra's Avatar
    Apr 2015
    Hernando MS.
    20
    Re: quick question
    Thanks...might add some DE to the filter. I don't mind it taking a few days and guess I was thinking that it would anyway. Just wanted to make sure I wasn't missing anything.
    Aqua Rite T-15 SWG
