Results 1 to 12 of 12
Thread: Bonding an Intex Krystal Clear Sand Filter Pump
    May 2017
    FairviewPark/Ohio
    9
    Red face Bonding an Intex Krystal Clear Sand Filter Pump
    Hi Everyone!
    Has anyone attached a bonding lug to an "Intex Krystal Clear Sand Filter Pump for Above Ground Pools, 2800 GPH Pump Flow Rate, 110-120V with GFCI" ? If so, how? It's plastic as far as I can tell, but I don't believe it's double insulated and would need to be bonded? Am I missing something?
    Thanks for all your suggestions!
    Lizzy
    CJadamec's Avatar
    Apr 2016
    Quaker Hill, CT
    2,192
    Re: Bonding an Intex Krystal Clear Sand Filter Pump
    A lot of the Intex equipment is double insulated and doesn't require a bond nor does it have a bonding connection. If it doesn't have a bonding point and the manual doesn't say to bond it specifically don't bond it.
    Chuck-
    15x30 AG, Pentair Superflo VS, 19" sand filter, TF-100 test kit
    Aqua Comfort ACT750 heat pump / 6x20 ground mount solar panel / DIY automation
    Photos of 2016 Build, Inside Your Breaker Panel, Free Copy of 2017 NEC code
    TFP is AD Free and is funded solely by member support click here to help
    May 2017
    FairviewPark/Ohio
    9
    Thanks Cjadamec! The weird thing is they do sell a model (I think it's a cartridge type) and it specifically says "double insulated", but this one (the sand filter) does not. There is also nothing in the owner's manual about bonding, and I can't locate a bonding point on the filter.
    CJadamec's Avatar
    Apr 2016
    Quaker Hill, CT
    2,192
    Intex equipment was designed to be used with un-bonded pools. It wasn't until recently that code requirered most larger (42 inches and deeper) intex pools to be bonded.
    Chuck-
    May 2017
    FairviewPark/Ohio
    9
    Ahh..that makes sense. My pool is over 42". So if it's not double insulated, and can't be bonded because there is no bonding point, then I think I got the wrong filter!
    CJadamec's Avatar
    Apr 2016
    Quaker Hill, CT
    2,192
    You didn't get the wrong filter you got a nice filter for your type of pool. You just don't need to bond it. That shouldn't stop you from installing a bond loop and bonding your water and running a bonding wire to where your pump will be. Down the road you may upgrade your pump or add something that needs to be bonded.
    Chuck-
    Eaglei22's Avatar
    Apr 2017
    IL
    37
    So does an intex pool need to be bonded if the pump is double insulated, per code or not? I am confused reading this thread.
    Jun 2012
    western NY
    1,662
    All pools should be bonded. If the pump is a double insulated model it does not have to be included in the bonding grid.
    Dan
    Unknown make 18' above ground (bought used in 1999) Sparco sand filter. Hayward 100,000 BTu heater. 2 speed pump
    CJadamec's Avatar
    Apr 2016
    Quaker Hill, CT
    2,192
    Any pool with over 42" of water per 2014 code is required to be bonded.
    If a double insulated pump is used a wire from the bonding loop shall be run to the pump but not connected for future use in the event the pump motor is changed. Not a direct quote but that is in the paragraph in the code book referring to double insulated pumps.
    Chuck-
    Eaglei22's Avatar
    Apr 2017
    IL
    37
    Okay, so the bonding needs to be installed even if its double insulated but just not connected (available for future upgrades to pump) to be code compliant?
    CJadamec's Avatar
    Apr 2016
    Quaker Hill, CT
    2,192
    Yes you need to have a bonding grid around the pool. The bonding grid does more than just bond the pump. Even if you had no pump you are still safer with the area around the pool and the water being bonded.
    Chuck-
    Eaglei22's Avatar
    Apr 2017
    IL
    37
    Okay thank you. I posted a new thread as there is some confusion with my current setup. If you can take look to help I would appreciate it thank you.
    Bonding intex pool with retaining wall base?
