Page 1 of 6 1234 ... LastLast
Results 1 to 20 of 105
Thread: Help please. It didnt look like this last time
    May 2012
    Baltimore, Maryland
    183
    Just pulled the cover and this is what it looks like. The pillow deflated during the winter so I removed it. Cover and pillow only 2nd time used.
    What to do first? I have the hose running. Can start pump as soon as water level rises.
    Can slightly see bottom. Looks mostly to be fine sediment. There are live mosquitos. Heavy brown algea content.
    Any advice I would appriciate.
    Thanks
    Tom
    15'x4' Metal Frame Intex 3yo (2nd year winterized) 16" 2650gph intex sand filter, Thru wall skimmer, dual inlet/single outlet, 1000gph intex pump (heater) Solar Cover TF-100 testkit, TFPC
    Mod Squad woodyp's Avatar
    Apr 2010
    East Texas
    10,158
    Re: Help please. It didnt look like this last time
    Use a leaf scoop net and scoop out all that you can. Post us up some test results.
    Pool School - SLAM - Shock Level And Maintain follow that.
    40,879
    I agree with Woody. Make sure that you fill it up and run the pump before doing any testing.
    Richard320's Avatar
    Jan 2010
    San Dimas, CA (LA County)
    20,311
    I concur. Get whatever you can out while it's filling. When it's full and circulating and mixed, post up some test results.
    May 2012
    Baltimore, Maryland
    183
    I will need to use a fine skinmer. The leaf scoop catches notta...
    I have a brand new kreepy krawley lil shark also...
    Dont add anything until test?
    May 2012
    Baltimore, Maryland
    183
    I guess the abnormal warm winter and shotty cover caused big problems this year.
    Only thing that was different this year is the skimmer was added. Guess I need to make a block off plate. The year prior I left the inlet and outlets open. But it was a lot colder of a winter...
    Apr 2010
    East Texas
    10,158
    ------how would you know what and how much to add? You know how this works around here!
    May 2012
    Baltimore, Maryland
    183
    Yeah I do... I figured I get a little something going but ill wait. Pump almost ready to go. Little more water and the inlet is covered.
    I got 3 gal of 8% bleach guess i better get 3 more. I have a box of borax so i should be good. CyA still half a bottle of granual so I think I just need some bleach.
    My lil shark doesnt have a prefilter so I can either hook it up to the side wall inlet. Or I have a skimmer plate..
    Maybe get a couple paint strainers for my skimmer basket to prefilter.
    May 2012
    Baltimore, Maryland
    183
    FC0
    CC0
    TC0
    Ph 7.2
    Cya im sure is around 20
    I just fed 1 whole gal into the inlet. 8%
    40,879
    What is that a cup of?
    May 2012
    Baltimore, Maryland
    183
    Its not pee. Its the water from the return... thats what I used to test with before the gal of bleach
    40,879
    That water is an interesting color
    domct203's Avatar
    Jun 2015
    CT
    3,900
    Do you fill from a well?
    Dom - TFP Guide
    Intex 18' X 48" Ultra Frame AGP 6700 gallons | Two Intex CS8110 SWG's | Hayward Pro Series 21" Sandfilter | Hayward 1.5HP Power Flo Matrix pump | Hayward Thru-wall Skimmer | Wanda the Whale | 72 sq ft of Sungrabber Solar Panels with Hayward GLC-2P-A | Taylor K2006 Test Kit, Sample Sizer & Speed Stir | Click Here To Become a TFP Supporter!
    May 2012
    Baltimore, Maryland
    183
    No i do not... we have city water. The water that was on the cover is the same color as in the pool.
    40,879
    Probably tannin from leaves.
    May 2012
    Baltimore, Maryland
    183
    Test after 1 gal
    FC.5
    CC10
    dumping another gal. Going to store.
    May 2012
    Baltimore, Maryland
    183
    Atleast im prepared on this end
    40,879
    That is a CC of 10.0?
    May 2012
    Baltimore, Maryland
    183
    Correct. I added another gal. Im out getting more. Ill test when i return. Already backwashed once
  20. Back To Top    #20
    40,879
    This is again suspiciously like a case of ammonia.
