Thread: Adding chemicals
    Jun 2016
    Manteo north carolina
    51
    Question Adding chemicals
    I need to add salt and cya. Can I do both or should I add one and wait to add other? Thanks
    Above ground intex 24x 52 Swg with sand filter pump. Well water. New started the end of May. 11,600 gallons. Test kit TF100
    30,941
    Re: Adding chemicals
    Add them at the same time.....no harm.
    Jun 2016
    51
    I am adding cya in sock in front of return. Is it ok to leave my sand filter pump on filter mode or do I put it on recirculate while dissolving?
    Richard320's Avatar
    Jan 2010
    San Dimas, CA (LA County)
    20,296
    Quote Originally Posted by blsobx View Post
    Filter. And if the filter needs backwashing, no worries. The CYA is in a sock, not inside the filter. That's why we recommend that method.
    Jun 2016
    51
    Thanks Richard. Just to clarify, I don't have to wait a week to backwash? How about testing cya do I have to wait a week? Thanks again
    Richard320's Avatar
    Jan 2010
    20,296
    Backwash whenever you need to. Hold off testing CYA for a day or two after it's all dissolved and the sock is empty, to allow it time to completely disperse.
