Results 1 to 20 of 20
Thread: Intex SWG flashing low salt Considering newer model Intex SWG - NO COPPER electrodes
    PoolMumsy's Avatar
    Apr 2017
    Ft Worth, TX
    36
    So I got a new Intex18x52 online last year to replace an 18x48. It's kind of turning into a money pit, but I'm learning alot, so I'll count it as good.
    After one year of use, the Intex SWG started out this season with intermittent flashing "low salt" after about one week of use producing sufficient levels of chlorine...no significant rain, salt levels testing at in range multiple ways, no cell build up....
    The only change has been an upgrade to a 2500GPH pump to accommodate a pool cleaner.
    Any suggestions or advice before I get the new model with a warranty?
    Intex Ultra Frame 18' x 52" pool, Intex Krystal Clear 15k SWG, Intex 2500GPH pump , Intex Auto Pool Cleaner
    Previously owned an in-ground gunite pool /hot-tube with a Nascent Oxygen Generation purification system. Frankly, it was the bomb, but grateful for Intex.
    Patrick_B's Avatar
    Jun 2011
    Midland TX
    14,999
    Re: Intex SWG flashing low salt Considering newer model Intex SWG - NO COPPER electr
    Ill go against the grain on replacing the SWG and suggest manual Chlorine addtion. It won't be that much of a hassle, and shouldn't be that much in quantity either. Just a suggestion, but a very simple solution.
    Essential Links:
    Jun 2015
    Stockholm, Sweden
    261
    Try adding salt. It may be low despite tests in range.
    Intex Ultra Frame 24'x12'x52" (732cm x 366cm) rectangular pool
    Intex SF80220RC (1600 GPH) pump/sandfilter
    Intex SF10220 (1050 GPH) pump/sandfilter driving the
    Intex Automatic Pool Cleaner
    Intex 8220 ECO SWG, Brilix XHP100 9kW heatpump
    PoolMumsy's Avatar
    Apr 2017
    Ft Worth, TX
    36
    Thank you, the trichloryl-ethelene build up from just using just stabilized chlorine has always been a reaction problem for use. in ground we used an nassent oxygen generating system and shocked weekly with bleach, above ground we switched to SWG as soon as I realized it was available.
    Is there a way with an above ground that I may not know about to keep sanitize the pool and produce chl besides stabilized chl shock? we live in hot and very sunny Texas.
    Thanks for any additional suggestions you may have.
    Richard320's Avatar
    Jan 2010
    San Dimas, CA (LA County)
    20,312
    Have you tried cleaning the cell?
    PoolMumsy's Avatar
    Apr 2017
    Ft Worth, TX
    36
    Quote Originally Posted by Mickelin View Post
    Thank you
    I added an additional bag yesterday. That makes a total of six **correction**seven and a half (300lbs). Testing it again this morning. Would the need for sodium change from year to year, in that the sensor or something in the mechanism necessary for salt levels becomes less sensitive and requires more to function?
    As long as it is producing sufficient chl (which it is/was up until the last few days when it started to show "low salt" consistently rather than intermittently with all other factors remaining generally the same) is there a way to recalibrate it or overide it so it keeps running?
    Thanks for any additional info.
    Thank you
    Yes, did a full cleaning of all the equipment two-three weeks ago on set up. Actually took the cell out to inspect it. I've done a visual check almost daily because of this intermittant "low salt" and there is no build up on or even between the plates.
    I'll go check again.
    I'm stumped.
    Thank you
    I'm stumped.
    Mod Squad pooldv's Avatar
    DFW, TX
    24,974
    There isn't any stabilizer in bleach or liquid chlorine. You can use that to maintain FC level without adding CYA.
    PoolMumsy's Avatar
    Apr 2017
    Ft Worth, TX
    36
    Thank you
    I have used liquid bleach, in the past, to shock my in ground. When I bought the Intex, somewhere I read to not use liquid bleach. Is that kind of like the "Do Not run the SWG with swimmers in the pool!" rule.
    That would be great to know as a stop gap until I figure this problem out.
    I so appreciate y"alls help.
    Jun 2015
    Stockholm, Sweden
    261
    Sure you can use bleach in an Intex pool. That's what most people here who are worried about corrosion with an SWG use. Go ahead and use it temporarily until you sort out your SWG problem.
    domct203's Avatar
    Jun 2015
    CT
    3,900
    I use bleach everyday in my ultra frame.
    Dom - TFP Guide
    Intex 18' X 48" Ultra Frame AGP 6700 gallons | Two Intex CS8110 SWG's | Hayward Pro Series 21" Sandfilter | Hayward 1.5HP Power Flo Matrix pump | Hayward Thru-wall Skimmer | Wanda the Whale | 72 sq ft of Sungrabber Solar Panels with Hayward GLC-2P-A | Taylor K2006 Test Kit, Sample Sizer & Speed Stir | Click Here To Become a TFP Supporter!
    PoolMumsy's Avatar
    Apr 2017
    Ft Worth, TX
    36
    Awesome!! Good to know, thank you.
    Quote Originally Posted by domct203 View Post
    Wowza!! Good to know. Do you have a protocal you are willing to share?
    PoolMumsy's Avatar
    Apr 2017
    Ft Worth, TX
    36
    Well, Hallelujah!! Miss Fussy Pants SWG just decided to kick in and work again, today. Here's hopin' for no more "low salt" readings and a full swimming season from here on out.
    I am interested in hearing more about using bleach as a sanitizer regularly. I'll search for threads, but if someone wants to share...much appreciated.
    Blessings from Texas, y'all
    PoolMumsy's Avatar
    Apr 2017
    Ft Worth, TX
    36
    Quote Originally Posted by Patrick_B View Post
    Thank you
    I just saw these links. Reading.
    Richard320's Avatar
    Jan 2010
    20,312
    Quote Originally Posted by PoolMumsy View Post
    It could be something as simple as the water was too cold.
    Anyway... for using bleach, it's really easy. You run a FC test. You go to pool math and enter your current FC, your target FC, your pool size, and what strength your chlorine is. It tells you how much to add. You go out and stand next to the return while the pump is on and pour the bleach into the stream. That's it. The only difference is that somewhere else they have a gigantic version of your SWG and they bottle up the output and sell it to you. Chemically, there's really no difference.
    Setting the target means knowing your CYA level, which also requires testing. But it doesn't change much.
    What happens is that eventually you know exactly where to dose your pool so that FC doesn;t dip below minimum for your CYA and day after day it's the same amount and you just wander out for a few seconds and dump it in, testing a few times a week just to keep tabs on things.
    There's more detail in Pool School - PoolMath
    PoolMumsy's Avatar
    Apr 2017
    Ft Worth, TX
    36
    Thank you for all the information and further direction.
    Very helpful and much appreciated!!
    jmcdtucson's Avatar
    Jun 2014
    332
    When my low salt indicator starts to go off, it usually means the cell in my SWG is going. Seems like I have to replace it every year - just got my new one under warranty since it decided to stop working one month *before* the 1 year warranty ran out instead of 1 month after like usual.
    I hope that is not the case for you, but something to keep in mind.
    Intex 12'x24'x52"
    8,403 gallons
    Intex SF60110 2450 GPH Sand Filter
    Intex CS8110 SWG
    Aquabot AJET121I Pool Rover S20-40
    PoolMumsy's Avatar
    Apr 2017
    Ft Worth, TX
    36
    Quote Originally Posted by jmcdtucson View Post
    Thank you.
    I have wondered about that as an unfortunate design issue.
    It started up again yesterday and ran for a boost cycle to catch up on chlorination.
    This morning...it ran for fifteen minutes, then fussy pants...LOW SALT reading. One gentleman mentioned water temp as a possible issue. It's pretty chilly this morning (70), but was 90 yesterday and is to be in the 90's today through Thursday. I'm taking out the kayak and floaties and putting on the solar cover every night...hoping the increase in ambient and water temp makes the difference.
    I realize, the more I read on this site, that my first Intex SWG was one of the oldie but goodie, no cooper ones. I could have sworn that I kept it for parts when I bought this new pool that came with a new SWG last year. Hoping to find it up in the attic because it was still working and had been problem free for four years. If not...a new SWG may be in my future, but I will time the warranty expiration date and next years pool opening strategically if that's the case.
    Hopeful
    I just ordered a new cell for mine today after fighting the low salt indicator the end of all last summer. I knew my cell was out because I could usually see the water get cloudy coming off of the cell, and it was as clear coming off the cell now as it was going into the pipe. And I also used bleach in my Intex pool, when my SWG crapped out. Just use the TFP Pool Math link at the top of the page and it should lead you in the right direction as to how much you need. Keep your CYA level in check and it will save you from loosing too much chlorine.
    22' x 4' Intex Ultra Frame 11,000 gal, setup in summer of 2012. Hayward Power-Flo Lx 1hp 60GPM pump, Pentair SD 80 sand filter, wide mouth skimmer, all hard plumbed
    PoolMumsy's Avatar
    Apr 2017
    Ft Worth, TX
    36
    This statement just MAY save me an unnecessary Intex SWG purchase. It was in the 80-90's for the last two days and the SWG decided to kick back in and run two full cycles, including a boost. Today it was 70 degrees in the AM...it ran 15 minutes, then urrrrgh...another "LOW SALT" reading.
    I remembered your temperature comment and waited til it got in the 80's....BOOM!! It's been running for three hours so far
    Could be a fluke, but I'm hoping I just got a temperature sensitive SWG. That is an easy and free problem to solve.
    Hopeful & Thanks!!
  20. Back To Top    #20
    PoolMumsy's Avatar
    Apr 2017
    Ft Worth, TX
    36
    Thanks so much!!
