Results 1 to 7 of 7
Thread: Ladder options
    May 2017
    Cross Hill, SC
    42
    Ladder options
    I am having my AG pool installed sometime in the next week... weather is holding us up. My question is that I am going to have a deck put up around my pool but not immediately. Am I going to have to buy two separate ladders or is there a ladder that I can use now that will conform to a deck later?
    24' round, 14,600 gallon AG with 20 mil vinyl liner. Haywood 150 lb sand filter, Haywood 1.5 HP pump and Haywood Aquabug Automatic Pool Cleaner. Taylor Tech K-2006 test kit. Installed 6/1/17
    Patrick_B's Avatar
    Jun 2011
    Midland TX
    14,999
    Re: Ladder options
    Hey Kim, welcome to the forum!
    I'm giving you a move and a bump to the AG area, where plenty of AG owners can chime in. Hope you have a great summer in your new pool.
    Essential Links:
    KarenNJ's Avatar
    May 2017
    Newfoundland, NJ
    223
    Re: Ladder options
    same question here! Hope someone has a cost effective idea!
    rajung's Avatar
    Mar 2015
    Iowa
    255
    Re: Ladder options
    I did this
    bought a Confer brand ladder
    look up confer plastics, the have many " A" frame ladders.
    Pick one and also order a deck conversion kit.Make sure the ladder you choose will accept the conversion kit, appears 4 or 5 of them do.Use it as a A frame ladder, when needing to mount to deck, you cut the back legs off and attach the deck kit.Basically sliding 2 pads with legs into each hollow opening left when cutting off, just double measure when cutting.They also have extension kits, which I needed since my deck was a little tall for the ladder.Very strong but the safety barrier is a little annoying since upper portion like to come loose.
    I removed after the 2nd year.
    couple links below
    Products | Confer Plastics, Inc
    Pool Ladders A-Frame
    Doughboy AG 16' x 32' oval, 13,700 gal.
    AquaView by Doughboy 150lb sand filter model 0-1709-20
    PowerLine pump by Doughboy model 0-3047-200, 1.5hp-single speed-20amp
    Gulfstream electric heater-HE125-R-A
    Taylor K-2006 test kit
    May 2017
    Cross Hill, SC
    42
    Re: Ladder options
    Thank you for the suggestions. So I purchased the Confer A-Frame 7200 ladder and conversion kit. It will be awhile until the deck is built and I don't want to screw holes in my pool top to stabilize the ladder. Any suggestions??
    Aug 2016
    Chapmansboro, Tn
    36
    Re: Ladder options
    Kim, I adjusted my ladder to just touch the top rail of my pool. Cut a piece of pool mat and put between ladder and top rail so the finish does not get rubbed. I use a 14x14x1 paver on the bottom platform of the ladder and it's as solid as can be without being bolted down.
    Bill
    New (Aug4th) AG, 8400gal, Ecokleer sand filter (45gpm max)
    1 1/2 hp Century ecokleer pump, Taylor K2006 kit
    May 2017
    Cross Hill, SC
    42
    Re: Ladder options
    Thanks Bill!
