Results 1 to 9 of 9
Thread: Leveling with dirt taken from high side on slope?
    KarenNJ's Avatar
    May 2017
    Newfoundland, NJ
    223
    Has anyone had their installer take the high side of the slope and use that dirt to build up the low side without issues? It is a gradual slope, nothing major but I understand it is recommended to dig down the high side to level with the low side and not add dirt to level. This installer is the company recommended by the local pool store, does ton's of jobs. I asked them, aren't they concerned about settling and they said not at all, the equipment is packing everything down. I live in NJ, with rocky soil. Looking at a 15x30 or 18x33 oval.
    Edited to add: The one side is probably just under 2 feet higher than the other side
    pabeader's Avatar
    May 2015
    Cartersville Ga
    4,316
    Re: Leveling with dirt taken from high side on slope?
    I did that with my pond. But it's only 2500 gallons. I used blocks to create a backfill area and then supported it all with concrete and rebar. I did dig down some but only to create the general shape of the pond.
    So I would definitely look close at what the supporting structure is going to be...
    Bob - INTEX 12x24 owner (not setup yet), 'New to me' Kreepy Krauly Sand Shark, Test kit: TF-100 w/Speed Stir
    JoeSelf's Avatar
    Jun 2014
    Glassboro NJ
    419
    Dug down to level on my pool, almost 20".
    13700 gal, 32'x16'x54" AG oval, vinyl, Echo Canyon II, 8500 series, Narrow Yard, Safety Fence & Stair, Sta-Rite Crystal Flow T-210WF, 44 GPM, Hayward SP1580TL 1HP Pump, Aqua Luminator, Festiva wedding cake steps, March 2006, TFT-100, Speed-Stir, Sample Sizer. Avatar Credit: TJ Townsend
    KarenNJ's Avatar
    May 2017
    Newfoundland, NJ
    223
    KarenNJ's Avatar
    May 2017
    Newfoundland, NJ
    223
    Quote Originally Posted by JoeSelf View Post
    Did you put in a retaining wall? How much room did you allow to walk around the pool?
    Mod Squad woodyp's Avatar
    Apr 2010
    East Texas
    10,152
    Enough said.
    KarenNJ's Avatar
    May 2017
    Newfoundland, NJ
    223
    yea, I am surprised the company said they do this since this is the pool installer the store uses.....
    JoeSelf's Avatar
    Jun 2014
    Glassboro NJ
    419
    No retaining wall. Pool was good for backfilling up against it.End view of pool.JPG
    May 2017
    Gaffney, SC
    26
    I will have to take some pictures, but the slope in our backyard is so steep, our 52" high pool is only a foot or so above ground on one side. The pool installers used the dug out dirt to level it up some. My in-laws formerly had a 27', 48" pool (in the same area as our 33',52" pool) for many years (8-10 years) with no problem, and the land had been dug and leveled the same way. I can't say for sure that your pool will be ok, but it has worked on our land, in the same place even, as our current pool, so I didn't have any problems with the installers doing it the same way again.
    Serena 33'x52" AGP, 25,600 gallons
    1.5 HP Pentair Pump, Heyward Sand Filter
    TF-100 Test Kit, Speed Stir
    PH Pen
