Thread: How to Add Liquid Chlorine
    May 2017
    Lawrenceburg
    42
    I've read on here that most people pour their bleach strait into the pool in front of a jet. Instead, could I pour the bleach into the skimmer first, then allow the bleach to come out of the jets?
    My thinking on this is if I pour the bleach into the pool in front of a jet, I'm afraid some of it will fall strait down and settle on my liner and cause stains or fade marks.
    Any insight?
    34 X 19 23,000 Gallons; Vinyl Liner; Built 1984
    300lb Howard sandfilter - single speed motor
    1 skimmer, 1 main drain, 2 returns.
    Dolphin S300i Robot Cleaner
    TF-Test Kit
    Pyrodav's Avatar
    Dec 2016
    Chillicothe/ohio
    175
    Re: How to Add Liquid Chlorine
    Very few things are recommended to put directly in the skimmer and Chlorine is not one of them.
    You can dilute the Chlorine in a 5 gallon bucket with pool water and then pour slowly into the pool in front of a return.
    Also you can brush and agitate the water after you pour directly in front of a return to make sure it got mixed good.
    7000k Viking fiberglass Bermuda, Sand filter w/glass, Pentair SuperfloVS, Pentair IC20 swg
    Raypak 106k, Dolphin s-200, Taylor k-2006c, Taylor k-1766, Speedstir, Little Giant cover pump.
