Thread: How to remove decomposed leaves (black soupy mess)
    Leeinoh's Avatar
    Apr 2017
    Warren
    21
    I've removed all the leaves and sticks. There is some slime left over. Can this slime be floculated out after refilling, or do I need to remove every last bit of this mess manually. Thank you.
    40,000 gallon IG with a vinyl liner
    Hayward 244 sand filter
    1.5 HP pump
    Kreepy Krawley vac
    30,941
    Re: How to remove decomposed leaves (black soupy mess)
    If it goes through the leaf net (and you have a sand filter) I would vacuum it out.
    Vacuum to waste if you can afford the water loss. Vacuum to filter and backwash every time your psi goes up 25%
    Leeinoh's Avatar
    Apr 2017
    Warren
    21
    Thank you... I need to fill this pool before the $5000 liner dries out too much.
    1.5 HP pump
    Kreepy Krawley vac
