I have an automatic vacuum that is connected to the circulation system. Should it be running during the SLAM process or should we just have the pump running? Should the pump run 24 hrs a day?
I know it says to remove debris first and we did. However, I can't see the bottom of the pool but I am sure there are probably some leaves and debris down there. There is not much because we got most of it out. The vacuum is pulling out leaves though.
