Thread: Help fix return fitting leak
    Oct 2011
    Minnesota
    164
    We have been battling a leak that has seemed intermittent over the last few years. We now have located at least one leak at a return fitting that was installed in the fiberglass stairs. The fitting is crooked and had a large silicon caulk joint around that has slowly degraded. Not sure if this has settled or had been like this since installation. Since it is glued in, is the only option to clean and recaulk? What about a larger epoxy patch? Thoughts on how to repair?
    Thanks
    20x44 IG vinyl. Intelliflo, Pentair Cartridge Filter (420ft^2), Raypac 336K, Kreepy Krauly
    Apr 2015
    tucson, arizona
    1,312
    Re: Help fix return fitting leak
    A+B Epoxy Putty - Rezolin, LLC, I would try this. Clean area really well of residual caulking first
    Oct 2011
    Minnesota
    164
    I will look into that epoxy. Who sells it? Can you get it at a home store: Menards, Lowe's, home depot?
    Richard320's Avatar
    Jan 2010
    San Dimas, CA (LA County)
    20,310
    Quote Originally Posted by jmhjgh View Post
    It's on the website Where to Buy Epoxy Putty - Rezolin, LLC
    Oct 2011
    Minnesota
    164
    Thanks for the information. The repair seems to be holding. Hopefully, for a very long time.
